I'm becoming disenchanted with Tekton ratchets. I used to think they were the bee's knees. However, the ratcheting mechanism in all of mine is noisy, the same as my Harbor Freight and Taiwanese Craftsman; when I disassembled the latter two, there was absolutely no lubricant inside, despite my being the original owner and lightly using them for a few months. I believe that my Tekton are the same.
Giants, you lost me on CLA. I read the acronym thread and I am still lost.
What is it lubricated with ?
I purchased a Gearwrench 81309 1/2" ratchet and it was literally unusable. Rough, noisy and would catch and lockup in one direction when I tried to turn it with my fingers. Took it apart and it was bone dry inside. Not a speck of lubrication. Lubed it with a light coat of moly grease and it's like a completely different ratchet. Much quieter, smoother and now works in both directions. Why are all the manufacturers sending them out without any lubrication when they work so much better when they're lubed?
I take apart and lube every ratchet I buy now and it has made a big difference in all of them. They all become much quieter and smoother with just a little lube and a few minutes of work. Why this isn't done at the factory is beyond me.
.the Tekton website says their ratchets are lightly lubed from the manufacturer with a break in oil (not verbatim). That sounds to me like they are expecting the buyer to lube the tool when needed.
I've been reading about the Tekton 90 tooth. I was in Meijers the other day and fondled them. I've got myself thinking that I "need" that 90 tooth 3/8" ratchet with the eighteen inch handle.
I use the 1/4 & 3/8 drive 90 tooth fixed & flex head without quick release versions at work daily. No issues. I like the handle shape and ratcheting action is smooth as butter.
I wish Tekton would come out with a non offset handle 3/8 drive flex head ratchet measuring approx 13 inches long overall and a similar 1/2 drive version measuring 17-18 inches long overall.![]()
Seriously, I compared a 72 tooth (non-Tekton) ratchet to my 90 tooth Tekton and could not feel a difference and notice one, though admittedly I wasn't working in a tight space*. Can anyone else?
My next project is to replace a Toyota water pump…my 3/8" ratchet with shallow socked would not even be able to access it; I didn't think to try my 1/4" ratchet. Any alternative tools there?
Which version of Super Lube is used for this kind of thing? (12004?)The ratchet was noisy. I added Super Lube. It's as quiet as a church mouse.
My employer (industrial) requires me to wear cut-proof gloves. So for me, Quick Release ratchets are necessary.Man, I could see this thread costing me some coin... I do kinda wish they offered a 90 tooth 1/4" drive non-QR bent flex.
I always used grease in my ratchets. I found it causes 'false neutrals' in fine tooth ratchets. Now I use gear oil, have no problems, and they're quiet.I've bought a few new ratchets over the past year and a half and they have all been lubricated from the manufacturer.
None of them were from Harbor Freight. They were SK, Carlyle, Cougar and a Tekton composite. I completely clean, dry and lubricate every ratchet I buy.
I'll probably sound like a Tekton commercial by saying this, but.....the Tekton website says their ratchets are lightly lubed from the manufacturer with a break in oil (not verbatim). That sounds to me like they are expecting the buyer to lube the tool when needed.
I've had the same experience. I've always used Super Lube in all my ratchets. When I converted one of my Matco ratchets from 60T to 88T using grease would cause lock ups & the direction lever to flip sometimes. I thought it was the spring tension being too light. Switched to a light a oil & the problem went away.I always used grease in my ratchets. I found it causes 'false neutrals' in fine tooth ratchets. Now I use gear oil, have no problems, and they're quiet.
My 90 tooth is at work, but I don't believe its "backwards". Today bought a HF 3/8" drive ratchet with 2 flex joints in handle. Didn't realize it was backwards, am considering returning it. Hard to learn a new trick after 44 years of ratcheting. I have also heard of soaking the heads of non-sealed ratchets in ATF. If ATF is sufficient lube for the tooth to tooth pressure of a transmission, I'm sure it's good for up to 100 ft-lb of torque that a ratchet might experience. When I worked under vehicles every day, I would clean and lube my ratchets once a month. Craftsman ratchets would show tooth chipping in about a year. That was in the made in USA days.....I've had the same experience. I've always used Super Lube in all my ratchets. When I converted one of my Matco ratchets from 60T to 88T using grease would cause lock ups & the direction lever to flip sometimes. I thought it was the spring tension being too light. Switched to a light a oil & the problem went away.
Didn't know this thread existed. I have one Tekton ratchet that came in a socket set. I believe it's a 72T. If felt rough out the box & was noisy, opened it up & it had no lube either. Put a bit of light oil & that did the trick.
But that's not what bothered me. I can't stand that the direction lever is backwards. If I switch the lever to the right, I expect it to loosen a fastener, & switch left to tighten, but nope! Drives me nuts. But whatever, the Tekton set lives in my truck under the seat so it doesn't see a lot of use. If I had to use that ratchet often I definitely would have replaced it with something else.
Are their 90T ratchets "backwards" also?
Yup I hear ya. I've only got a bit more than half the years of ratcheting than you, I've never had a "backwards" ratchet or even knew they existed until a customer gave me one of those stubby dual drive ratchets when they started popping up everywhere. Besides the Tekton, those are the only backwards ones I thought I had as I always check now before buying a new ratchet, well so I thought.My 90 tooth is at work, but I don't believe its "backwards". Today bought a HF 3/8" drive ratchet with 2 flex joints in handle. Didn't realize it was backwards, am considering returning it. Hard to learn a new trick after 44 years of ratcheting. I have also heard of soaking the heads of non-sealed ratchets in ATF. If ATF is sufficient lube for the tooth to tooth pressure of a transmission, I'm sure it's good for up to 100 ft-lb of torque that a ratchet might experience. When I worked under vehicles every day, I would clean and lube my ratchets once a month. Craftsman ratchets would show tooth chipping in about a year. That was in the made in USA days.....
