Tell me about generac generators
overdriv
Central IL
I have a chance to buy a 15000KW Generac generator new, never used, never had gas in it till today. I don't know who or where the engine is made. The generator unit has a tag on it that says, made in the USA. but I can fing nothing that suggest where the 30hp engine is made?? the engine. Model is oe6221.
It is a2009 unit that looks new in every way. the guy wants $1600.00 for it.
Can someone tell me if this is a good unit or run away?
Thanks
Ross/Kzoo
Richland Mi.
That's a steal. I've had my 15KW Generac for 12 years now and the only thing th tawent bad was a natural gar regulator valve @ $450. Mine is liquid cooled Mitsubishi engine. About three weeks ago mine operated for 75 hours straight. I was told by a friend that the water cooled unit were less likely to require service. That's an excellent deal from what you've stated.
bob from indiana
harrison county indiana
That is a pretty big generator. Remember it will take a lot of fuel to run it.
The 5000 watt size is popular around my area. They generally use 5 gallons in 8
hours. I would read up on fuel consumption before I bought one that big it
might be overkill for some jobs.
amolaver
$1600 is a great deal on 15kw generator..but i've heard horror stories with generac. is it a portable (wheeled) unit or stationary? looks like a replacement motor is about what you're paying for the whole unit - http://www.brandnewengines.com/0e6221.aspx
that said, i'll take my ex-military diesel MEP-003 '10KW' over any of the common consumer stuff. you can find them at government auctions (and possible newer models as well). its a loud, air-cooled, onan diesel, but it should last roughly forever with my use (~100hr/year), and will have parts and expertise available for just as long.
what are you planning on using a generator for? mobile power? house backup? off-grid part-time power on a long term basis? just keep in mind if you're planning on connecting it to your commercial-power connected home, there are some (potentially significant) costs associated with either backfeeding a breaker - with interlock, of course - via cord/plug or transfer switch.
ahm
Generac probably made the engine in their plant in WI. I have no real proof, but I think it is a reasonable facsimile of a Brigs&Straton Vanguard twin cylinder Vee.
If it runs on gasoline, you had better have a large supply on hand for emergencies. This is a problem because gasoline should not be stored for more than about a year.
I assume it does not have an automatic transfer switch. Wire it in to your panel using a generator interlock. Not expensive.
O
overdriv
Central IL
It is a wheeled/portable model. I think it's says Guardian, on it. It has a 10 gallon fuel tank for gasoline.
srmofo
SW ohio
That thing is going to eat you alive on fuel unless you really need that much power.
HunterWare
Central VA
I have that unit and it will power a surprising amount... my well, water heater, 3ton AC (seriously), and the rest of my misc usage. I bought it knowing I needed something right now in my new-to-me country house, and knowing that this would "get me out of jail" until I could get a real whole house unit. It has done the job perfectly. I've been without power 12 days out of the last year and it has got me through it. I'm looking forward to the convenience of an LP whole house system with auto-switch, but this gets it done.
It has a 16gal tank and that runs over 12 hours for me. I got 5 5gal tanks and that lasts a couple days, I always use stabil marine to keep the gas and run hi-test. I lose power enough that I'm not worried about the gas sitting for over a year, and the 3-6month intervals haven't been a problem. Also I pull from the oldest can for filling my oil-mix can which helps too. I tried to run it in a 3 sided covered shed once and almost overheated it. I don't do that anymore, it's a monster of a portable generator and needs to breath.
One other thing: the outputs are as listed in the post above... 50A-220V, 30A-220V, and several 110s at 20A. This means you can't pull the full 15.5kW into a single panel (since that's over 50A-220V). That works ok for me as I have two panels and I can wire the 50A to one (with the AC) and run the rest of the stuff on the other panel off the 30A. It's not perfect, but got the job done. You could hardwire to the main conduit with a 70A breaker if you knew what you were doing, since that is what their breakers and plugs are coming from... but you'd kiss the warranty goodbye.
I've been running it at heavy load for days at a time (sucked a bunch more fuel then, almost 2gal/hr), during the storms on the east coast last summer it was hot and it ran flat out for a week. It's a solid unit. Not what I should get long term, but it's proved its worth no question.
Hope this helps,
Hunter
DIC
That's a deal but it will eat you up in gas. Iv got a 17500 Generac, Ran it a couple of weeks during hurricane Rita cost about $40 bucks a day to run. And that's shutting it down about 8 hours a day.
nehog
Jaffrey, NH
That's a relatively inexpensive generator set sold by HD, Northern, and a few other resellers. IIRC, they sell for a bit more than the seller is asking. Might be worth it, but IMHO I'd suggest a price of about $1250 (or less) would be more realistic.
O
overdriv
Central IL
Thanks for all the info guys. I passed on it as I had to buy it soon or it was going to be sold to someone else. I did offer him $1200, but he wouldn't take it. I guess I missed a good deal, but not knowing all the above I was a bit leary to buy it.
Thanks again.
frankzlt1
Beacon Falls ct
that unit has the same motor as the home standby. it is a made in the USA generac engine. you can get a natural gas or lp conversion kit. there is a company in texas that sells the kits. i will find out who it was, my boss went to one of the generac seminars and meet the owner that does the kits. the only problem that i found but not with all of them is they will hunt on rpms. a quick fix is disconnect the ct's inside the control box. the only way to fix the problem permanently is you will need to send it back to generac.
Gregory M
shelley, idaho
I ordered a powerhorse 9000 last week from northern tool delevered for $1,050 TO Idaho. Read about 59 reviews ans 98% gave it high marks.i should get mine tommorow, cant wait to set it up and try it.its 9000 wats surgeand 7250 watts continues.check it out i think you will like it.
Greg
