Captain Spaulding
Being retired, I thought remodeling a house was a good plan, so I bought one!
It really isn’t too bad. Not updated since the 70s, but maintained. Nothing urgent to fix, but modernizing and adding a bath and a half will make it a much more attractive property.
There is a lightly insulated barn that’s 40x80 with a gravel floor that is fairly weather tight. My plan was to use this as my work area, cutting trim, stripping and sanding and making new mill work. I have my table saw, miter saw, router table and some tables for cutting sheet goods in there.
Works out, but I just can’t keep it warm!
Think about blocking off the area I’m working in and reducing the heated area. 14’ to the bottom of the trusses. I’m thinking I could pick a truss, nail foam board to one side and hang plastic tarps from the bottom cord. Light, cheap and fast. Not good insulation, but I just want to take enough chill off so I can work bare handed and not need to bundle up like crazy. Not heating it all the time, just while I’m there and using it. I had though about framing a wall, but then when it gets hot again I’ll not be able to open doors at both ends for a breeze.
I’m expecting this to be a couple of year project.
Comments or better ideas?
