Terminal release tool
SuzukiGS750EZ
Who makes a nice automotive terminal release tool set that won't break the bank? I don't use them but a few times a year but when I do I need to get inventive to get them to release. When I worked in the shop we had the star type ones but there has to be something better.
Fedwrench
Valley of the sun
what do you work on mostly? the reason why i ask is that with some connectors, the OE tool works best and might be cheaper in the long run.
If you go to amazon, you can grab the steelman kit which is pretty complete, rebadged by many, for under a $100. If you want cheaper, they have steelman kit knockoffs for less than $60. still want cheaper, there's the classic 3 piece kit from Lisle, along with the much cheaper beaded chain collections. Good luck in your quest. :beer:
marineman
Wild Rose, WI
I forget the part number but I have a small snapon kit that works pretty well for everything I've needed. Price was pretty reasonable, $60 or $70 if I remember right.
signcrafter
I'm assuming this is the steelman kit referred to wondering if the kit I listed above is as rigid as this kit strength wise and why two more tools in the other kit for cheaper. https://www.steelmantools.com/automotive/electrical-service/universal-terminal-tool-kit.html
I have the steelman kit and don't use it often but it sure is nice to have when needed. No clue about the quality of the cheaper knockoff set but for 40 bucks more I think I would just go with the steelman. Pay once and cry once.
2ndGearRubber
Pittsburgh
I have the snap on kit, it's like 130. I'd highly consider purchasing the individual tools you need for what you work on. High quality depin tools aren't super expensive if you're just buying a few.
LXCam
I have that kit and it’s pretty generic. It never seems to be the exact fit but I’ve always made it work and to date nothing has failed. Like fed and others I’d suggest buying the factory tool if you only have a couple specific types of connectors to deal with. But this one will work given a little patience and talent.
rlitman
Long Island
I can't bring myself to do it[emoji23][emoji1787]
To be clear, I’m not saying that that set is up to regular use, or is anywhere near the class of the real tools being tossed around here. Just that for my half a dozen uses per decade, it’s been better than nothing for me.
