Test icode format option
Shadowdog500
Down the shore
With ICODE:
05 HOME : TEXT : REM Fibonacci numbers 10 LET MAX = 5000 20 LET X = 1 : LET Y = 1 30 IF (X > MAX) GOTO 100 40 PRINT X 50 X = X + Y 60 IF (Y > MAX) GOTO 100 70 PRINT Y 80 Y = X + Y 90 GOTO 30 100 END
Without ICODE:
10 LET MAX = 5000
40 PRINT X
50 X = X + Y
70 PRINT Y
80 Y = X + Y
90 GOTO 30
100 END
Shadowdog500
Down the shore
With ICODE:
module module1 integer:: n contains recursive subroutine sub1(x) integer,intent(inout):: x if (x < n) then x = x + 1 print *, 'x = ', x call sub1(x) end if end subroutine sub1 end module module1 program main use module1 integer:: x = 0 print *, 'Enter number of repeats' read (*,*) n call sub1(x) end program main
Without ICODE:
module module1
integer:: n
contains
if (x < n) then
x = x + 1
print *, 'x = ', x
call sub1(x)
end if
end subroutine sub1
end module module1
program main
use module1
integer:: x = 0
read (*,*) n
call sub1(x)
end program main
Shadowdog500
Down the shore
With underline
With strikeout
Georgia Font
New Times Roman Font
Aerial Font
Book Antiqua Font
Tahoma Font
Trebuchet MS Font
Verdana Font
Shadowdog500
Down the shore
Red and yellow and pink and green
orange and purple and blue
I can sing a rainbow
sing a rainbow
sing a rainbow too.
What Children’s show is that from!
Answer! Click below
Captain Noah
Shadowdog500
Down the shore
With code </>
Code:
10 LET MAX = 5000
40 PRINT X
50 X = X + Y
70 PRINT Y
80 Y = X + Y
90 GOTO 30
100 END
Tom Graham
Oklahoma
Test to attach PDF natively to a post using the “Attach files” functionality (as requested by Jim.)
edit: and it works …this large file example is 5.4MB.
  • Craftsman Bench Grinder 397.19590.pdf
