Test light with 2 leads instead of a probe
johninct
Does anyone make a test light with 2 leads instead of a pick for up to 24 volts? I am working on an excavator by my self and need to actuate stuff in that cab and at the same time, see the test light and have it hooked up. I have been using jumpers clipped to the test light pick but all in one, with long leads would make things easier for me.
Ricky Joe
Roanoke, Va.
Make one.
I made one for trailer lights a long time ago. Nowadays I would just screwclamp an extra Long lead to the pointy probe for the few times I need it. Once used a 110v extension cord as the extra long lead. My buddies looked at me like I was an idiot, but it worked fast and easy.
Bad Eye Bill
New Brunswick Canada
This may or may not be helpful in your situation.
I made a tester for checking stuff while working alone where visibility was a problem.
Took an old key in ignition/headlights on buzzer, added a couple of leads. Was now able to test various things from a distance while operating the controls.
richfinn
Leeds, Yorkshire, England
The OTC mini test lamp has a threaded section on the probe tip
You can buy a 4mm banana plug adapter that fits the test lamp
I cut the alligator clip off my test lamp wire and added another 4mm plug
Now I can hook it up to any kind of probe or extension lead (I like to use my power probe extension so I can have power and ground for the test light)
You need the battery clips too
I realise this seems like a lot of ridiculous work and expense for a simple test lamp, but what did you expect on GJ? 🤣
This kit makes a very useful tool for bypass testing and stops you having to walk backwards and forwards all the time to switch from positive to negative and you have 100% reliable connections
If your in the USA try "Jarhead diagnostics" as he sells some of Warwick Test Supplies stuff
silvertina
philippines
This is your answer. I also have done this using wire size AWG #18. Redneck solution but got the job done.
no704
I made one for trailer lights a long time ago. Nowadays I would just screwclamp an extra Long lead to the pointy probe for the few times I need it. Once used a 110v extension cord as the extra long lead. My buddies looked at me like I was an idiot, but it worked fast and easyI
I once used an extension cord to supply music to an out door party. From the amp in the house. Tied all grounds together, N,and L were left and right channels.
crewchief888
NW indiana
made one up with stuff from an electrical surplus store. long set of leads, alligator clips, aluminum box with a magnet attached, a large panel light and a buzzer
  • Like
Reactions: RTM
