How can I test this motor starter, i.e. the 120 volt coil.
9 930dreamer Super Moderator Staff member Joined Oct 7, 2009 Messages 23,130 Location Amarillo,TX and Stinnett,TX Sep 4, 2015 #1 How can I test this motor starter, i.e. the 120 volt coil. Attachments 20150904_134637.jpg 134.1 KB · Views: 44 20150904_134643.jpg 133.2 KB · Views: 42
R rat55chevy Member Joined Dec 26, 2010 Messages 16 Sep 4, 2015 #2 Apply 120 to the screws with red wires. Power on the left ground or common on the right. Make sure its clamped down if ur bench testing.
OP 9 930dreamer Super Moderator Staff member Joined Oct 7, 2009 Messages 23,130 Location Amarillo,TX and Stinnett,TX Sep 4, 2015 #3 10-4 on having the starter clamped down, that thing clunks when it closes, thanks. And the coil works.
M Mr. T Well-known member Joined Sep 4, 2013 Messages 636 Location Central PA Sep 4, 2015 #4 Even if the coil works it might be worth it to pull the cover and see what shape the contacts are in.
W wyliesdiesels Well-known member Joined Aug 14, 2012 Messages 20,279 Location Modesto, CA Sep 4, 2015 #5 Mr. T said: Even if the coil works it might be worth it to pull the cover and see what shape the contacts are in. Click to expand... The contacts may be pitted and burnt...
OP 9 930dreamer Super Moderator Staff member Joined Oct 7, 2009 Messages 23,130 Location Amarillo,TX and Stinnett,TX Sep 4, 2015 #6 I'll look into the contacts. Thanks
O OccupantRJ Well-known member Joined May 15, 2009 Messages 11,562 Location Eastern North Carolina Sep 4, 2015 #7 Some contacts can get expensive to replace, so be aware of that.
M Mr. T Well-known member Joined Sep 4, 2013 Messages 636 Location Central PA Sep 6, 2015 #8 Even if they look a bit pitted and burnt you can usually clean them up and get more life out of a beast like that.
OP 9 930dreamer Super Moderator Staff member Joined Oct 7, 2009 Messages 23,130 Location Amarillo,TX and Stinnett,TX Sep 6, 2015 #9 I have a 30hp 3 phase motor that I was going to use this starter for, this would be for a rotary phase converter.
