Jeff Ivers
Wanted to try some electroplating and needed a DC power supply. Have a couple dozen AC/DC adapters/chargers. Thought I should check them to make sure they were working and to select the best actual voltage one for my experiment. Got out my 30 year old multi-meter and tried to check voltage and amperage rating of all the adapters I had in stock. On about 75% of them, I could attach my test leads to the power plug from the adapter (that was plugged into a working outlet) and get a voltage reading. On some, I was not able to get a reading, but thought the adapter should be good, so cut the plug off the end and bared the two wire leads and re-tested. If I didn't get a reading, I reversed the pos/neg leads and tried again, assuming I may have mis-interpreted the polarity. Still no reading. Since this one (that had no voltage reading) had the best voltage rating based on the label, I decided to go ahead and use it on my electroplating experiment. It obviously was putting out current as the electroplating worked. I could see the voltage flow as indicated by the bubbling on the anode.
Why am I not getting a voltage reading on a device that is obviously putting out current? Is there something about the internal design of some of these adapters that prevents testing them in the manner indicated?
I also tried to check amperage output and my readings started getting even more weird. In one case, I obviously had the test leads in the wrong range on the multi-tester (too low - potential overload). Decided the multitester might have a problem, so took the back off and discovered corroded batteries. I removed the batteries and cleaned off the corrosion and installed fresh batteries. I then commenced re-testing and still was getting no voltage readings when I thought I should.
Once the new multi-tester came in, I rechecked my previous tests and still could not get a voltage reading on the adapter that worked for the electroplating.
To get an accurate current reading on these in a test mode, does the adapter have to be plugged into a load?
Thanks, in advance, for any insight.
