I strongly suspect the floor was poured 4-5 inches thick and out of 2,500-3,000 psi concrete with reinforcing wire. (Which is difficult to determine whether it is wire or rebar with a metal detector) My opinion of wire is that it offers very little strength and all it does is holdthe cracks together. I always use rebar in my concrete slabs) I wouldn't be as concerned as much with the strength of the concrete as I would the thickness. The base of the lift post should be wide enough to spread the weight over the concrete that concrete strength shouldn't be that much of a factor. You can determine the thickness by drilling into the slab and determining when you hit dirt or gravel. If the depth is deep enough for the bolts for the lift then you should be ok.
If not then as sasquach suggested, saw cut out an area and replace it with thicker high strength concrete. This will have to be doweled into the old concrete though which can be a daunting task to do correctly.
