EdT
I have a two bulb fixture on my blast cabinet. It uses two 15 watt T-8 bulbs much like you might find in a desk lamp. I left it on for a couple of hours and when I returned the lights were no longer working. The ballast is a "trigger" ballast and there is no separate starter. According to the label on the ballast there is a one time thermal fuse which I suspect may have died. The question is, is there any way to check the ballast function before I go buy another one. I know that I have input voltage, but I took readings on pretty much every combination of wires on the output side and I see nothing. I'm a bit naive on electrical stuff so any help would be appreciated.
Thanks
Thanks
