Last fall I bought a 16" Echo chainsaw from Home Depot for something lighter and safer than my 50-year old McCulloch, which never had a chain brake. I used the Echo a few days last fall and once last week. But last week I could not get it started again about an hour after I used it. It wouldn't even attempt to start so I checked for spark. I removed the plug and grounded it while cranking. No visible spark. Pulled the kill switch wire from the coil. Still no spark. Switched to a known good spark plug and still no visible spark even when spinning the engine with a drill. Tried an inline spark test light and no visible light there either. Tested both the spark plug and the inline test light on my McCulloch and there was good spark and blinking light by just spinning the flywheel by hand.
The Echo's plug gap and the coil to flywheel air gap are both good. The ignition coil's secondary winding measured around 2.7k ohms, which appears good. I understand you can't test the primary winding on these newer coils (it reads about 120k ohms) so I ordered an OEM replacement coil. Same result. No visible spark at the plug or test light. I used Echo's online support to get the coil test specs (2.5 - 2.9k ohms) and they recommended I bring it to their nearest servicing dealer.
Today, before I headed to the dealer, I spun it again and still no visible spark. I put the plug back in and installed the cover and it fired right up. What? The saw still has problems starting when its warm so I brought it to the dealer for testing anyway. Is there something about these newer engines that prevent seeing a visible spark at the plug while grounding it to the block? Lower voltage? No spark unless there is compression? How do you test for spark?
