Thawing a water supply line?
nitrohog
Illinois
I'm in a bit of a pinch at the moment. My main feed into my house has frozen and after multiple failed attempts to thaw it I'm open to any suggestion. So far the water department has refused to do anything, I can't get a plumber with a steamer out for another few days, and it has been frozen for the better part of three days already. I have so far managed to get a small tube 20' up the pipe but I believe the city shutoff valve is stopping it. At that point I have tried back flushing it with warm water for a total of around 6 hours and even tried damming it so that it would fill the pipe and circulate warm water in. I attempted to use steam but the cold pipe didn't allow the steam to reach the end of the tube with my redneck pressure cooker setup. My fear and best bet is that it is frozen under the street another 15ish feet upstream. With the vast knowledge here hopefully someone has better idea than me.
Thanks.
Sent from my Transformer TF101 using Tapatalk
pattenp
Virginia - USA
If it's frozen on the city side of the shut off then it is the city's problem. Why are they refusing to help?
N
nitrohog
Illinois
I've learned that for whatever reason in this city the homeowner is responsible for the pipe all the way up to the main which happens to be across the street.
Sent from my Infected Rezound using Tapatalk
JaredC
Broken Arrow, OK
I own a plumbing service company in Oklahoma and it sounds like you are kind of stuck. You aren't going to be able to manually thaw a water main that has been froze for that long that is underground without some specialty equipment.
We carry electric thawers that resemble a portable battery charger and usually it takes no more than 30 minutes. But every area uses different materials and strategies.
I wish I could give you some more helpful advice, but in this case there just isn't any unfortunately.
Do you know what material the water main is piped in? Is it PVC, pex, copper or galvanized?
finn
The UP, God's country
The city would dig down to the frozen pipe with a backhoe and attach an engine driven welding rig to the pipe when I was a kid in Upper Michigan. I would imagine just attaching one lead to the shutoff valve from the main line and the second lead in your basement would work.
I don't know what they set the amperage to but would imagine it was quite low.
N
nitrohog
Illinois
It is a copper pipe. I thought about the welder trick but if I have to dig up the road to hook up a lead I'm just going to dig the pipe deeper and replace it anyway. You basically just told me what I was expecting to hear, I guess I'm in for a long wait for the thaw and learn to let the faucet run when the frost gets this deep.
Ray-CA
San Diego CA
Could you wrap a heating pad around the pipe and turn it on?
Ray
PS: Are you the only one on this line without water or is it a neighborhood wide thing? Sounds like a phone call needs to be made to your City Councilperson/alderman etc. If you are without water for this long, it's now a health issue. Can't flush the toilets and how are you cooking? Any children in the house? You've got some leverage...
N
nitrohog
Illinois
I've been carrying water in 5 gallon containers for the toilet, been showering at the girlfriends parents house, and have been eating out/at their house as well. Thankfully I live alone, no kids, and work a lot so I'm rarely home anyway. My neighbor to the west has been out of water for a week longer than me and said that she's tried everything within her power to get the city to do anything for her and all that they suggest is to borrow water from neighbours. I'd love to raise some serious hell with my alderman but on the other hand fear that the city may condemn due to the health reasons that you've stated. It's a double edged sword with the way the city water system is setup. Also there's no way that any amount of heat that I can put into the pipe is going to travel 20+ feet through frozen ground. I had a 1400 watt heat gun on it for several hours before I resized how far up the blockage was.
Ray-CA
San Diego CA
I think that you might want to consider calling the local newspaper and/or the TV stations. They can't condemn your home because the City water lines have frozen. Any worries that the water lines have split farther upstream....You might want to also call your homeowners insurance since your home is now un-inhabitable. See what they have to say.
Ray
JaredC
Broken Arrow, OK
If its copper it won't take long to thaw with an electric thawer. The ones we carry on our trucks run about 800$. Maybe you can rent one?
Sureshot
Bridge Creek, OK
Sounds like it is under the street. If not cover the line with straw and a tarp to use the ground heat to begin thawing from the bottom up. If you don't the frost will continue to travel down. Cover it ten feet on either side.
If you can get pex or synflex down you can circulate warm water in or make a "heater" by running two hoses inside each other, plug the end of the outer one at the downline end. Slide the smaller one inside to within a few inches of the end. On the end of the outer one you need a threaded fitting to accommodate a tee. Slide the tee over the inner pipe and attach to the outer pipe. You will need a compression fitting for the inner hose(synflex) that has been drilled out enough to let the hose slide through but still "crimp" the compression fitting. Slide this over and install in the tee. Tighten the fitting into the tee and squish the ferule on the line. Put a fitting in the side of the tee. I have two of these with 1/2" pex as the outer and 1/4" or 3/8" synflex as the inner. They sit in a pipe adjacent to my domestic water out of the house and into the shop.
You can now circulate down the outside of the inner tube and back up the middle without losing fluid. I would hook it to my truck heater line and let it run. It may take a day or more depending on how far it needs to thaw it but the longer you leave it the worse it will be. The heat will travel in the pipe some and thaw the ground around it. Even if you don't get it now you will be able to get it a lot sooner in the spring.
If you have a water based boiler system you could use the water line itself as the outer tube. This would be best so you can leave it work when you are gone and if it does unthaw it will be sealed up and not flood you creating a new problem. Possibly use your hot water heater and some garden hose and a pump to keep it warm under there and it will thaw eventually.
I am sure you are aware of the implications of being caught circulating antifreeze in the water line but the city doesn't sound like they are showing up any time soon so I would do it despite what the safety police will say. The line will be thoroughly flushed if you get it moving.
If the line is frozen under the street where it is open to air and being driven on you need to get on it soon or you are fu$%ed as the frost will travel quick.
PM me via email if you need a pic of the setup.
kaffine
Henderson, NV
How about hooking one lead of the welder to your water line and the other lead to your neighbors water line?
Not sure if it would work as both might be grounded through the electrical system and that may provide the better path. Also there may be dielectric unions to provide isolation from the city main or the city main may be plastic.
cinco
Northern CO
Nitrohog, for a moment I thought you were me.
I've been dealing with almost exactly the same problem for the past 3.5-4 days myself. Mine is frozen somewhere between the meter in my front yard and where it comes through the pad at the back of my garage, so it's definitely my problem. Slab house so no access to anything, and plastic pipe so no fancy electrical tricks. Guess now I know how long it takes to freeze 6-feet deep at 40-60 degrees below freezing. Anyway, my last resort before calling a plumber is going to be some of that roof heat cable that you can buy to keep your gutters from icing over. Seems like if I can work it past an elbow or two it'll run right up to the ice plug and warm things up. But as we all know, in theory, theory and practice are the same; in practice, they're not. I'll let you know if I'm killed in spectacular fashion.
ghost68
We've had ours freeze up at the meter before. If you think it might be frozen there or the main cut is close, get a board big enough to cover the meter, some insulation, and flexible exhaust pipe. Cut a hole in the board the size of the pipe. Insert the pipe through the board, pack insulation around the meter/cut off and place the board over the meter. Back you vehicle to where it will reach the pipe. Hook the flexible pipe to your vehicle exhaust and let the vehicle run. Ours thawed out in no time.
Ghost
N
nitrohog
Illinois
I bought a chunk of hard plastic tubing and managed to get it about 30 to 35 feet up the line which near as I can tell is approaching the road. I'll see if I'm stuck against something else or if I am able to make some form of progress. Only time will tell.
galute
Bald Knob AR
Will hooking a vacuum pump to it work? I know ac tech's use vacuum to boil water out of ac systems. I have no idea if this would thaw ice. I'm sure someone who knows will be along shortly to tell me this is a dumb idea. LOL.
SteveCh
I had to be away from home for a week in Dec. due to a very unexpected death in the family. While I was away, freak storm, up forecast, came thru and a section of my well pipe is frozen, first time ever, shows what a week of minus 15 F. can do, even six feet underground.
I spent days trying everything I could think of, finally resorting to using 3/8" clear hose and pouring boiling water into it via a tiny funnel. After three days of this, I had to admit defeat. Went to Lowe's and bought ten 5-gal buckets and am hauling water. Using the laundromat for washing clothes, etc.
Nothing I can do til summer, ground frozen from the surface. Pain in the ****, but what you gonna do.
Milton Shaw
A welder with long leads should be able to hook up to your system and a neighbors system and thaw the pipe quickly. Have faucets open in both houses so when the ice melts the water will run. From now on let water run in tub during cold weather to keep this from happening again. Ridgid tools sells a couple of pipe thawing tools. They are step down transformers that step 120 volts 15 amps to 6 volts about 200 amps. Found one on Ebay a couple of years ago and bought it for $25 I think. I bought 50 foot of leads for it and am ready whenever my pipes freeze. Knowing I have the tools the pipes will never freeze.
jimindm
Des Moines, Iowa
My mom has the same problem. Has lived in the house 35 years and has never had a problem in that time. They had the new main supply brought in about 20 years ago. The city water company says there are no outages in the area, and they have not shut any water off for a few weeks. About 6 months ago the water company offered an insurance plan for the line between the main and the meter. Its $3.99 a month. I told every one that I knew, you should buy it. For the monthly cost, it would take many months to over ride the cost of a problem.
I called a few plumbing friends about the situation, and they all kind of laughed and said" its happening every where, from million dollar homes, to shacks in the woods". They had a few ideas of why its happening. Most every one of them had to do with the lack of rain fall and ground moisture. The ground around foundations and stop box valves is actually pulling back. Letting the extreme winter temps get down into the now available air space. Lack of snow fall to insulate the yards, allowing the frost much deeper than normal. What snow that has fallen has been plowed off of streets, so lines that run under the streets are even more in danger of freezing.
Many thawing methods that plumbers used in the past are shelved. They have not been used for a long time. Maybe nobody knows how to use the equipment any more. With plastic lines the norm now, most any method would be old school now.
I think the OP is also a part of the problem. He lives alone and likely does not use much water. As opposed to a household of a family with kids using a lot of water.
Its really just an act of nature. Mother nature has not been great to many across the US. You can not prepare for the ultimate misfortunes. You can only be prepared for what your general needs are.
I really have nothing to offer the OP as far as getting water running to his house. Other than he is not alone in this situation.
In my moms situation, insurance does not cover freezing lines. That's not a bad thing actually, because what is the fix. It does how ever cover any thing that she is not negligent in doing. So we will wait it out. If it has burst after it thaws, then she is covered.
Just took the kids to school, and a block from the school they started building a couple of houses in the fall. They are close to being finished. There is water shooting up through the ground in the front yard of the center house. Its flowing towards the houses downhill and flooding the street and homes behind them. The water in the street is up to the side walks now, and still rising. It looked like the water company just showed up on the scene.
Took a picture of it and sent it to my mom. This is three blocks from her house. She texted back" You just do not have to look far to find someone in worst shape than yourself".
Buckgnarly
VT
This only lowers the boiling point temp by lowering the vapor pressure, does not affect the actual temperature at all....but good thinking out of the box:thumbup:
N
nitrohog
Illinois
Just a slight update. Im about 60' up the pipe with my plastic tube and still pumping warm water. I have a guy on standby that offered to let me use his welding rig but the only way to get continuity is to hook onto the neighbors house then mine and let it burn... Im not a big fan of that idea personally.
JakeKohl
Greenville, SC
That welder trick just feels like it has "watch this wreck" written all over it.
N
nitrohog
Illinois
Yeah, putting that one on the back burner for the moment. I'd hate to utter the words "hold my beer and watch this".
arsco
Ma
we used to hook the welder to the street key while it was down hole on the shut off. no need to dig.
onewheat
Knoxville, TN
I would have thought that the homeowner is responsible from the meter IN, not from the main IN to the house (like the electric, cable and phone). So if the line breaks under the street, you are responsible? I call Bravo Sierra. What do they do - fix it and bill you or are you responsible for digging up the street, repairing the main and then fixing the street as well. No way!!
jhelrey
MN
The other trick is to use a steam machine and a few nozzles to get down to poly hose size. Then you shove the hose in the copper line instead of hot water. The steam works much faster!
Spareparts
Lansing Ks.
Just remember to hook the leads to the pipe then start the welder, I did it the other way one time and the results werent good.
finn
That's how I remember it. City crews probably did a couple a day when it got real cold with little (only a foot or so) snow cover.
Of course we were tougher back then....
RPH
Michigan Thumb
I have used table salt poured into the pipe to thaw it. If you can get the pipe in that far blow a salt slurry in there and give it some time. Last time I did this was on the outside faucet at the barn. Twenty minutes later I geyser from the salt working through.
pstnbly
So. Vermont
Nitro, you are doing the right thing, just keep pumping the warm water, you will get there eventually. We thaw a lot of frozen pipes in VT. The method you are using has the least drawbacks and potential for damage.
Just remember to leave the water running a trickle after you clear the blockage. The welder method is the next logical way to go. I've thawed 500' of 6" snowmaking pipe outdoors with this method, although it did take 72hrs continuous with a large portable welder to do it.
flat350
illinois
Just remember that when you do thaw it your going to have to get that hose out of the main in a hurry when that water starts flowing.
sberry
Brethren, Michigan
With a welder on needs to learn a bit about alternate pathways and I use a clamp on amp meter. I usually unhook the electric to plumbing ground.
cinco
Northern CO
Re: my earlier post: Didn't work, but I still think it might. It turned out that the hard plastic tip on the heating wire won't go through 3/4" pipe elbows. If I had 1" it would have made it.
N
nitrohog
Illinois
That is way the law reads. If it breaks I have to tear up the street, repair the line, and fix the road to their specifications. I talked to city hall and they said there's tons of people out of water in town. They aren't willing to do anything at all even if it's the main at this point. The only consolation they offered is that they wouldn't bill me next month if I didn't use any water.... I back flushed it for 6+ hours at the 60' mark and got no where. I'm up against something metal and I have no idea what it could be. The city shutoff should be around the 35' mark.
Also my only source of a welder backed out today too...
onewheat
Knoxville, TN
That is the most ridiculous thing I have ever heard. :confused:
