Between 265 & 485 SQ/FT The 12-Gauge Garage
ItsNemo
Canada
Re: Ever open up a Miata?
Miata's and Mazda's in general are surprisingly easy to work on once you find your way around them. I've done a couple clutches on some Mazda 3's and it's not all that bad.
unslow1
Illinois
That's neat to be able to do that together. I have trouble finding anyone who wants to learn and play with cars instead of play video games. A friend of mine struggled to get his Miata running properly for about three weeks after taking it apart. It turned out the firing order in the manual was incorrect. He talked a Mazda mechanic into stopping buy just to listen and he knew what was wrong.
chrismenke
Sam's Clam Disco, CA
I can't read the little placard and guessing that is some kind of intercom connection with the house? I don't see that thing working as a telephone on today's infrastructure.
"No Personal Calls"
Strangely, they do still work on a POTS line. Not sure if VOIP dial tone registers rotary pulses.
MushCreek
Upstate South Carolina
The only way I open up my '92 Miata is to open up the throttle. Yep, I unleash all 120 hp, and I ain't skeered. I do need to do a bunch of maintenance (radiator, hoses, belts, etc.) but I'm still waiting for the weather to warm up.
kellymc
I've got an 04 speed as well - the vibration is from the rear wheels not being dynamically balanced, try to find a shop that can balance them for you. Also, if you still have the factory 17" wheels, they bend pretty easy so that could also lead to vibrations.
DARNED sweet car, and definitely subbed to this one...
Any idea what caused the #4 rod to go? How many miles?
Not just academic, as we *also* have an 04 MX5 Mazdaspeed (also in that awesome gold-flaked red with black) and if its something we can watch for...
Right now, we have a weird vibration between 50 and about 75 MPH, I think it may be the driveshaft or ?? (Not the wheels or tires, this we do know), but it ***** it's at highway speeds.
Anyway, thanks for the story, keep us posted!!
fatfillup
Finksburg, Md
Funny you mentioned Miata's. Had a 95 for a while and am going to an auction today where a 91 is for sale. Not overly interested but if it is good and can be had for cheap, it might come home with me
ezriderga
NW GA
The closest I've come to opening up a Miata is shortly after I purchased my 1990 (first year) Miata two years ago from the original owner I replaced the valve/cam cover gasket. These cars were not designed to be fast...they were designed to be fun. Good of you to help your nephew out Jack.
ddawg16
S. California
You should have dropped a Ford 302 in it....like a buddy of mine did.....overall, an 'easy' swap. Really 'woke' the car up.
Can't believe you kept the floor clean during the process....
BTW.....when do I get a ride in one of your 'work' cars? I'll give you a ride in mine.
apollo11
State Of Reality
Fast IS fun
Miatas are a great chick car, meaning they are perfect for women.
My gal had one for a decade or so and it was perfect for her.
LateNights
Brisbane, QLD, Australia
Awesome memory & would have been an epic photo if you were a little better at selfies!!
Love that the nephew is an engineer too - hopefully he takes a page from your book and keeps the Miata running like clockwork!
(I've got relatives in Canada that own a shop working on everything up to exotics but they still run a Miata in what's known as the "chump car" series - bang for your buck they're hard to beat.)
Before I sign off - it's been a pleasure reading the thread - I'm sure you've heard it a million times, but it really is an inspiration, so thank you for inviting us all to follow along & all the best for the future!
You're not secretly Batman are you??
:beer: :lol:
Squankum
Southeast
Jack, we're both members of the "own and rebuild car again and again club" and don't need to label things... normally. (Lately, I've taken apart areas of the GTI and gone blank because it's been so long since the last time.)
Otherwise, just label things. Green masking tape and a Sharpie.
When it comes to oil level, you can get away with murder on the street driving like a normal dullard, but on track? You had better come correct! Weak links will be found. And his car doesn't have 12 quarts to work with!
So glad he got a chance to learn so much. Maybe he can keep this car forever and rebuild it repeatedly, too.:)
APEowner
Sunny, New Mexico
I suspect the low oil level was the cause of the starvation. I've seen it happen more than once with Spec. Miatas. While the missed shift didn't help things Miatas get miss-shifted a lot and usually it doesn't hurt the engine. I have seen more than one spin due to a downshift that was intended to be an upshift.
J
Jack Olsen
Los Angeles
There's a new front-engine car in the family. I'd had a BMW 328i for eight years, and it was surprisingly reliable for just about all of that time. Recently, though, I'd started having intermittent electrical/code issues that were starting to get frustrating.
So my solution was to find a car that was going to be even more complicated and electronics-dependent.
Brilliant, right? :)
This is a 2015 C300, which is Mercedes' entry into the same compact market. It's all-wheel drive -- and equipped with lots of gimmicks and switches and motors and screens. It's got radar and cameras and dozens different systems that can eventually give me headaches.
But for now, it's very comfortable and quiet for those days when I can't be out rattling my teeth in the 911 or the Jeep.
I'd always considered myself too young to be a part of Mercedes' target demographic. But looking in the mirror, I realize that I'm right smack in the bullseye -- silver-haired and barely able to figure out how to find a radio station with the thing.
It took me a little while to find one that was black on black with black wood trim. But I figure you can't go wrong with black.
TurtleValley
BC. Canada
Great choice for vehicle and colors.
Good luck with all the gadgets. I rented a similar Mercedes when I was last in Austria and had to keep pulling over on the side of the road to figure out the headlights (which just did their own thing for me anyways), change the media input from satellite to phone, or adjust the 87-way adjustable seats, heated seat-steering wheel-foot pedals-**** massager etc!! I never did find the microwave oven, missile launcher or Beer Chiller though.
Those Germans do think of everything though!
Volcrew
I'm not a SM expert, but I have owned an MSM for seven years and I suspect the problem could have been more uniquely an MSM issue.
The MSMs came with an oil catch can that drains back to the oil pan's starboard side. During track cornering, oil backs up the drain line and gets sucked back into the intake. The oil then pools in the lowest point of the intake track - the intercooler. It would be interesting to pull the hose off the intercooler and see if it is full of oil. This is a known problem with tracked MSMs.
Fortunately, there is an inexpensive fix. The drain hose is cut and a pcv valve is inserted to act as a check valve. This allows the catch can to drain normally while preventing oil from making its way backwards into the intake. Aftermarket suppliers like Flyin' Miata sell a little kit with everything needed for the check valve mod.
J
Jack Olsen
Los Angeles
We saw some oil in the intercooler plumbing. And we added the check valve when we put the engine back in.
It was definitely an issue. But would that cause oil starvation by itself? Or would it simply play a role in lowering the overall quantity of oil in the system?
J
Jack Olsen
Los Angeles
"No Personal Calls"
It works on my VOIP setup.
It's true about the complexity of operating all the stuff. I had ten immediate questions along those lines the day I got it. A Mercedes forum filled in some of the blanks for me. But I have had moments where I've simply pulled over to go through all the menus -- or set up the back-up position for the mirror -- or figure out how to disable the auto-locking feature...
Steve from Socal
Hutchinson Ks.
Jack,
Welcome to MB ownership, I am surprised you didn't get a C63. My C wagon is a hoot to drive, the small MB's have always been the best drivers.
Enjoy,
Steve
Squankum
Southeast
My Mercedes had a peculiar electrical problem recently, rough idle and low idle at cold starts. But it was merely the brushes on the voltage regulator approaching their wear limit. That's a 1989 model for you. You will have many more interesting problems. You'll probably need to get the boy to figure it out. :D
_
slik560
Kansas, USA
89....is it a 560SL by chance? I have something similar...a very slight lope at idle...so this might bear checking. In a month, poor Jack will find himself over at Benzworld.org, searching for the truth. :)
Squankum
Southeast
Naw, a mere W124 300E here.
See the most recent post at my thread, there's a link to Kent Bergsma's video about the voltage regulator and weird issues. I would never discourage you from checking your voltage regulator (disconnect battery ground strap, then unscrew two screws.)
But otherwise, your first concern is that you have a Bosch CIS-E car and vacuum leaks are critical. Inspect all air hoses on the vacuum side of the engine, and most of all, change all O-rings, seals, and plastic cups. (I'll be posting some pics about all of this at my thread... er... soon, I hope.)
Also, this many years down the road, consider cleaning your injectors (see also Kent Bergsma's website to buy an injector cleaning device, and for videos) or even just putting in new ones, they're only $24 ea. on amazon lately. (At least for my car they are.) (What I've paid for similar-but-different air-shrouded CIS injectors in the past makes $24 feel like a steal.)
A CIS car can run quite adequately for a long time and idle kinda ... okay... on some hilariously clogged injectors. Proper misty spray, however, makes everything much nicer.
Also, since you're selling this car, none of this is worth doing. That's why I fix problems and never sell cars. :D
_
slik560
Kansas, USA
:) I will check out Kent's site for the voltage regulator thing. I just can't leave it un-checked, even though the car is for sale. I did new injectors, plug wires, ICM, coil, and a retired MB tech friend went through and found scads of vacuum leaks. Lots of new hoses in that there car. But enough of hijacking Jack. I'll check your thread for future updates.
ckadams00
Seattle, WA
See, that's the difference between us mere mortals and you with the garage. At least in my case, my "all cleaned up" photo would probably be the first photo just without the car on the lift :bowdown:
Haven't visited in a while and MAN! was I happy to FINALLY see a picture of the shop is disarray! LOLOL this shop has been an inspiration to me for several years, great to see it messy!:rocker:
shortykorte
Tallahassee, Fl
Ah, man. Jack if you wanted a MB I have the project car, ‘95 SL320.
Never go wrong with black. Black is always faster.
J
Jack Olsen
Los Angeles
If this thing falls off, I'm going to feel like such an idiot
It's always suspenseful the first time you raise a new vehicle on your home-brewed lift.
But it worked. :beer:
d.mcfarland
Western PA
Re: If this thing falls off, I'm going to feel like such an idiot
Hats off to you. I wouldn't have the balls to lift that, and I'm a praying man.
Sure did, but that's a fairly expensive guinea pig. I'd have at least used 6X6 and ran it into the ceiling!!
Parrothead
Earth
I’d have probably picked a cheaper car for a test run, though that’s why we have insurance, right?
