I have been researching 2 post lifts diligently for the last 2 months (basically an obsession). I ordered my lift today, but though i would pass along some of the information i found to someone else who may be considering their first lift. i had a very hard time finding good reviews in forums and i thought i would share.
I have a 2 bay 32'x48' pole barn with 14' eves, so i knew that i wanted a clear floor style 2 post lift because real estate was not a problem. i was trying to keep costs to a minimum within reason, meaning that Mohawk, Rotary and Bendpak were out of the question.
My requirements were:
1) 2 post lift capable of lifting my extended cab long box f250 diesel
2) clear floor design
3) symmetric/asymmetric is still up for debate
4) needed to be 220v
5) budget was $2000 (....was when i started anyway....)
First Consideration: Atlas 9KOA
$1500.00 + Freigt
http://www.gregsmithequipment.com/Atlas-9KOH
i started my search with Atlas lifts from gregsmithequipment.com. i was planning on getting their run of the mill 9k 2 post lift for $1500 plus freight. this lift would have met my needs but there were a few things that talked me out of it
1) It uses a 2 point disengagement system (you have to disengage the locks on both posts). this was not a deal breaker, but rather an inconvenience
2) most everything you read about greg smith customer service is sub par to say the least.
3) it is not safety certified by any 3rd party
Second Consideration: Atlas 90HSC
$1700.00 + Freight
http://www.gregsmithequipment.com/Atlas-9OHSC-SS-Overhead-Two-Post-Car-Lift
At one point i decided that i would rather have the 90HSC because of its "Super symmetric" capabilities and single point latch release. this lift was a little taller than the 9KOA which i like. at one point i was dead set on this lift, but with further research i had discovered that the "Super Symetric" lifts were very noisy while lifting, almost as if the carriages are binding in the columns when lifting.
While researching again, i finally found the lift i was going to purchase......
Danmar Brigadier 10ACX
$2400 SHIPPED from equiptool.com
http://www.dannmar.com/dannmar-products/two-post-lifts/brigadier-10ACX.asp
i decided on this lift because it was certified, rated for 10k, weighs 300 pounds more than the atlas lifts and its an older Bendpak design. Bendpak sold their old design to Dannmar when they came out with their new one. This lift is a direct drive with much larger.. EVERYTHING.. I got the lift, shipping and a free 8 gallon oil drain for $2400 out the door. I post some pictures after i get it and start working on installation.
this post sounded much better in my head, but it sure was harder to get my thoughts across on paper.
$1500.00 + Freigt
$1700.00 + Freight
