Randyre
Well, after almost 20 years on jonesing for a shop the build has begun.
I have taken my friends advice and built bigger than I needed and now it even seems too small
I'm building a 40x40 with a 35x70 in a L shape. The 40ft is the man cave/arcade/theater and the 35x70 is the shop/garage.
My biggest hurdle in the design is that the space need is partially on a hill almost 9 feet off grade, and I have a well on the uphill side wasting almost 20ft on prime flat ground.
I'm going to do a pole barn with wall/footers to make up the grade, going to level as much as possible first. Maybe 5-6 feet.
40x40 will have 9ft walls and 35x70 will have 14ft
6ft porch along the 40ft section and 18" gables and soffits.
The other hurdle is the fact that I'll be putting solar on the south facing side of the 70ft, which also required me to orient the building in a way the did not allow me to maximize the flat ground which will necessitate even more concrete work, Arghh.
here's the plan, construction should start today! !!
Warning, Editorial content below
On Spoapbox
Off Soapbox
