The best adjustable wrench
fivespdcat
I like my Kleins.
I do have a Knipex Pliers Wrench but generally go for the 'normal' Kleins. If I had to choose between one or the other I'd ditch the Knipex.
First person I've heard say this.
Every time I need only one wrench, the Knipex is what comes with me. If space is not at a premium they are really unbelievable, never had them slip at all. The only issue I can see, is that the force is so great with them that if you're wrenching on something soft, it can deform them, otherwise they are awesome.
Another thing to consider for you, is if you're up on a boom you probably need tool control and the Knipex do not come with a hole to hang them by like a adjustable does.
Ruger_556
I personally despise the Proto Click-stops... different stroke for different folks I guess.
You use a brand new one? They're a challenge for awhile right out of the box, once they're broke in though man are they are nice... :drool:
oak_park
Chicago
Another vote for the Irega made Channellock Adjustables.
Whatever brand you choose, nothing beats inspecting it in person for any slop before you buy it.
Gmonkee
I have the new Bahco adjustables, made in Spain. They're better than anything I've found in the big box stores, and the made in Sweden ones must be legendary, as I quite like the ones now.
Legendary may be overkill but if the example I found is average of the production of the times they're worth seeking out.
The guys I've seen that collect the older Bahco can even date them to the decade at least . The thumbwheel works reverse compared to modern versions and that takes getting used to.
Most sellers don't know an old adjustable can be better than a shiny new on so these can go dirt cheap.. Mine was about $4 and a bonus of 60 odd years of crud to scrape off. I'm hoping to find a 'gator handled version like those that came in the '60s cars.
MaineGuide
Maine
Any one use Gedore adjustables?
They look pretty good, but too much coin to buy one just to try.
SteadyC
CA
I own(all coo US) crescent,diamond,proto,thorsen, WF,some others I can't remember. But the SO FAD12 has been the best so far. I got it in the mid 90's if I remember correctly.
cgv69
Boone Co., KY
One more vote for the Channellock/Irega's but I have been tempted to try the Bahco comfort grips
CNGsaves
KS and OK
Gotta say the "best" adjustable wrench is the . . . ONE YOU HAVE WITH YOU !!
If you don't have it, you can't use it !! :D
I've had oodles of Crescent and Craftsman adjustables over the years and all did the job . . . just had to have it WITH me at the time !!
Lately my hero is 18" Crescent adjustable which broke loose trailer hitch ball with help of 3 foot cheater pipe.
OP if money is no object, then get a set of SnapOn's and wrench away. However, for same money you can put Crescent adjustables in every vehicle AND every toolbox for the same money !! :bounce:
stonesfan68
Houston, TX
I have a couple of Snap-On adjustable wrenches and they are probably the worst ones I have used, they have extremely sloppy jaws. Any Ideas?
If you don't like the Snap-On adjustable wrenches then don't buy the Channellock or Irega versions as they are all made by Irega in Spain.
Crown Imperial
SE Florida
I have Crescent, Bahco and a Lobster. Both Bahco and Lobster have little slack and smooth thumb wheels. The lobster's jaws are a bit too thick for my taste.
The crescent isn't horrible but not nearly as good as the other two.
RBailey
Dubai, UAE (Arabian Gulf)
Here is my take on an adjustable.
It's a 250mm Stanley wrench with a hammer head and pry bar welded on, I also cut a slot in the handle to work as a shackle key.
I know its a ******* child. I use it at work for work on casualty / salvage response and finesse is not required.
jeremy v
I prefer the Irega made Channellock's for wrenches under 12", but there are many other brands already mentioned that are just as good. For anything larger than 12" length I usually prefer to use Ridgid hex wrenches instead of my larger adjustables. They don't fit in all situations, but they work in most situations I encounter. I have and use the following models. E-110 (lighter duty only), No11, No15 (not made anymore), No17, and No25 (for the really big stuff). They grip better because they pinch the bolt head a little bit when torquing and the "No" models can handle a lot of torque without issue. Their design also allows you to use a pair of pliers on the adjustment screw to crank it tightly onto the bolt head before torquing when breaking something loose (can't be done with regular adjustable wrenches) which gives a little extra protection against rounding of the bolt head.
stage20
pcola FL
I like my macs proto and blckhawks which should all be he same OE. My favorite are my usa craftsman. The head is a touch smaller for tight areas and their finish on hem is second to none. I don't know the OE for hem but they are nice tool.
OutsideMachinist
Norfolk, VA
image.php
azhatchback
Bahco/ snap on chrome ***** bad. Snap on USA is the best I have used. I use both. I don't have a single Bahco / snap version that the chome has not cracked to all hell. I got both flavors, Spain & Sweden. Both have **** chrome. My buddy just gave me a brand new 10inch snap on / bahco off the truck, never used and chrome was falling off. These are no where near the quality of the once USA SO and like most have said a lot of them have teeth on the JAWS. My 1O" does and 8" does not. If you find USA SO get them because they are not made anymore.
jd_1138
NE Ohio
I doubt if most of us use adjustables on a regular basis? I sure don't. Maybe once every 5 years in a pinch. :)
Ruger_556
I do, several times a day on occasion. I don't work on cars though.
Adjustables really don't have much use until you look beyond bolts. Air line Weatherhead type fittings, hydraulics, bracing manifolds while you're installing fittings, straightening metal brackets etc...
Crown Imperial
SE Florida
^^^ Yeah. And AN fittings. That's what I mostly use mine for. Damn wrench sizes for different AN fittings are impossible to remember. Easier to whip out the adjustie. Whoa pao!
azhatchback
Once you use Clik-Stop everything else seems like junk... They're nice :bowdown:
Never heard of clik-stop. Looks similar to craftsman USA. I have a full set of craftsman too from 6in to 15in. They serve me well along with my Snap On's. I prefer the good USA made SO when dealing with wet situations. They don't rust. If I have to really get on something I find the craftsman's are softer and the jaws will get dinged. Pretty common with bargain adjustables. So if your buying an adjustable to make up for lack of big wrenches I would look for a quality adjustable. At work we have a monster Proto for large high pressure cooling lines that feed the factory that is pretty good.
I mostly use adjustables when it comes to plumbing or making tweaks to metal brackets. I have not seen a better adjustable than a SO USA made with or with out the teeth on the jaws. SO really dropped the ball when they stopped making their own adjustables.
Deadsquiggles
Chesapeake, VA
I have 3 Crescent brand "crestaloy?" adjustables that stay in my bag and go with me on every job. An 8, 10, and 12 inch. They say "Made in USA" on the handle too.
exmaxima1
Midwest
Roughly 40 years ago Craftsman made great adjustable wrenches with larger thumb wheels and "click-stop" mechanisms based on a 1955 patent used on Williams wrenches. You might still find them used at the auction site.
My vote would go to vintage Diamond wrenches. And from my experience, it's always best to use the biggest wrench you can handle for the job. The jaws stress less, and you don't strip the heads of bolts.
ar_rahko
Hibbing Mn
I have an 8" channel lock adjustable. The best part is it opens up to 1 and 5/8". That comes in really handy after you break loose a big hydraulic hose and it is still to tight to unscrew by hand. It is not much fun to swing an 1 and 5/8" open end wrench that wieghs 10lbs.
Sent from my ZTE-Z990G using Tapatalk 2
ar_rahko
Hibbing Mn
xela456
Proto Click stop. Try one and you will never go back. You put it on one size and it does NOT move. No slips, no rounding and with the proto USA steel the jaws don't spread out. I had my first in a proto 15" spud adjustable and it is the best I have! nd you should have one too!
