The BEST epoxy floor system
sting ya
OK so who sells or which is the best epoxy floor coating system on the market, regardless of price ? doing a close to full cover flake
Cruzin90
That's like saying, "which car is the best on the market"?
However, there are only two epoxy resins: Bisphenol A and bispenol F. Bisphenol F is superior.
There are many curing agents (also called "hardeners"), but cycloaliphatics are probably the best curing agents.
If you go shopping for Bis-F epoxy, then you might as well look at a polyaspartic which is a different product, but may also suit your needs.
thegarageguy
No "BEST" system can compensate for good concrete preparation
Being properly prepared to install is another. Make sure you have all the proper tools and man power to tackle your project.
Or hire the right pro who has many similar projects under his belt and that stands behind their work.
Good luck
LegacyIndustrial
deerfield, IL
I will second what Fernando has said....
You should be asking, "who is the best applicator?"
and then look in the mirror and ask the fella looking back how well he does epoxy floor work.
