The best wire cable cutter?
Mr. Tool
Looking for the best wire cable cutter for a clean slice cut without any difficulty cutting or having to use the tool to cut the wire cable more that twice?
Regardless if the wire cable is bare or has a plastic coating, a good dependable wire cable tool that will cut without any hesitation, difficulty, etc. and will slice the wire cable in one shot, by the press of a hand?
I am looking for recommendations on hand held tool wire cable cutters....not heavy duty requiring two hands/arms bolt cutters.
As mentioned, wire cable cutters only.
Can anyone here in GJ please recommend their top choice's, regardless of price?
Thank's in advance to all who post! (y)
EDIT:.....some examples of different size types of wire cable.
shawhite
What diameter wire are we talking about. Also in your second picture the cable on the right and the 3rd from the right will require different cutters than the rest of the wire rope cables you illustrated.
abt12
Depends on wire size, but hard to beat Knipex 95 61 190 SBA Wire Rope Cutter if the size is right.
M6erfan
'Merica!
Agreed^^^
Yep, this would be my recommendation too although the largest rope wire I've cut with mine is < 4mm. I've never tried the Felco C7's.
For larger dia. wire rope I'm not sure a "one handed" cutter will suffice
