3GT
I'm planning to build a large partially conditioning post frame building (3000+ sq.ft) in the same location where my dilapidated barn (70Lx28Wx8H ft est.1991) currently sits. The new structure will be a dual/triple purpose area, 2-car garage, cold storage, and workshop. This will hopefully be my ideal building "buy once cry once"
I won't get into all the problems in order to stay on topic but for now assume the entire existing structure will be removed.
With this in mind, I'm undecided if keeping the existing slab to save on cost is worth the risk when investing so much into a new structure to build on it with the items I at least perceive as issues.
I'm not experienced with foundation/concrete work but have been researching for some time now and while I have learned quite a bit--not found anything that could push me far enough in either direction.
The significance of what I see as cons are what I would really appreciate some different perspectives on
I'm currently planning to do the concrete work myself with some help so this would primarily be the cost of the concrete, gravel, dirt, any forms, rebar, wire, pex, etc.
Also have access to a track loader but would need to rent a concrete breaker to remove
So have I gave up this slab too early? would you be comfortable building a expensive structure on top of the current slab?
- 70x28 Slab with no relief cuts
- It's a monolithic pour 5.5 inches thick with no footings (unsure about rebar/wire mesh)
- 4 ~1/8 - 3/16 cracks that run the width of the barn with a few other off-chutes (see pictures)
- Digging down it looks as though the slab was poured directly on top of dirt, no vapor barrier, insulation, or gravel
- Poor backfill (and lack thereof) around slab
