So the 2763 can achieve 1036 ft lbs of torque in reverse but can technically remove a bolt torqued to 1100 ft lbs as long as it's little warm......hence the claim of 1100 ft lbs of "breakaway" or "nut busting" torque.
Yes. Definitely not real world but a hell of a cordless impact wrench. Thank you for sharing the video. I did enjoy watching it and it has actually inspired me to go check out some more of his other videos.A warm, well greased and not rusted bolt, yes, very slowly. Real world 1100ft lbs, no. Which is the point of the video.
I'm not knocking the Milwaukee, just agreeing with the video that nutbusting claims are BS.
The entire video seems a bit dubious, measuring bolt tension and using it to infer torque. That works when tightening it, since tension and friction are working together to resist the wrench, but when loosening it the direct effect of the tension is to loosen the bolt. It's only the friction of the nut on the threads and plate that the tension increases.
Sent from my Nexus 6 using Tapatalk
Does anyone actually buy an impact based on its nutbusting torque rating?
Call me cynical but, I view every manufacturer's claims with a grain of salt. I think all of them manipulate data for the sake of marketing.
