Recently, I tore down an old storage building using the forklift to make way for the new cargo container. Unfortunately, it was too wet and muddy to burn the remains of the building then.
With the weather warming up I thought it was time to get going on that project. But first, I needed to make a hitch for the 14' flatbed wagon I recently got.
Initially, I intended to make a standard swinging drawbar for my Ferguson TEA-20 by copying the original design. However, I realized that would limit my ability to load and unload the wagon as I would have to dismount my boom pole to pull the wagon. (The forklift weighs around 7 tons empty and doesn't take kindly to off-road excursions.)
Here's one such example:
Then, it occurred to me, why not make a hitch for the boom pole? After all, towing a wagon is fairly light duty. I took a few measurements with the tractor next to the wagon, then parked it in the shop:
I made up a quick template in Illustrator and glued it to a sheet of 5/8" steel:
Sawed out the shape:
Drilled the 3/4" hitch pin hole:
And finally welded it to the boom pole:
Here it is in action:
It works well and negates the need to remove and install the boom pole every time I need to pull the wagon, which saves my back and a bunch of time! I figured I would post it up for anybody else who has an old tractor and uses a boom pole instead of a front end loader.
Not sure how exactly to mount it yet.
