Below 265 SQ/FT The Boxcar Shed
All workspaces below 265 squarefeet.
RichieP_MechE
Near Pittsburgh
Floorspace is starting to become limited in my garage, so I decided to start working on a shed to store my lawncare equipment. I want something that won't project into my yard to much, so I decided on a 5x12 lean-to shed that I could erect parallel to the back wall of the building.
As I started working on the design, an idea popped into my head. I decided to make it look like a portion of a railroad boxcar. I'm taking inspiration from an old P&LE boxcar that was on an old 4x5 negative that I scanned for a local historical society several years ago.
Rail nerds will note that the P&LE was never a part of Conrail, but I just love the Conrail logo so I wanted to include it here.
Construction will be 2x4 framing, MDO plywood sheathing, PVC trim, and a metal roof. Floor is a poured concrete slab. I'm still dialing in some details. Not thrilled about the basic door design, so I will spend some more time thinking about that. Also planning on adding a small awning over the door to help keep the rain at bay.
The first step completed was pouring of the pad a couple weeks ago, done by the contractor I had hired to add a parking area extension to my existing driveway. This past weekend, I put down some 2B limestone between the pad and the side of the garage.
My goal is to have this built by the time autumn rolls around. I'm partially making this post just to hold myself accountable publicly so I actually get it done 😅
Adaylate
Washington
I like it!
The wife and I lived in a Northern Pacific boxcar, converted to a kdb (kitchen, dining, bunk) car, early in my railroad career.
Good.luck with your project!
R
RichieP_MechE
Near Pittsburgh
Made a 3D printed jig to cut the rafters. My roof design doesn't have eaves, so I need to cut angles and a rabbet to fit the 2:12 pitch properly. Two pieces screwed down with #8 cabinet screws with a spacer piece in between to set the length.
I used my jigsaw to make the cuts
The rabbeted end uses a two stage method - cut a small notch and cute to length, then drop in an extension wing to finish the cut.
captain14
RichieP,
How much room between the boxcar and the house? Do you get to keep the forklift?
Do you anticipate electric in the future?
I’m sorta partial to the Chessie rail line symbol. That’s the tracks that run by my house. It was replaced by a new symbol.
R
RichieP_MechE
Near Pittsburgh
RichieP,
About 3 feet between the two structures (the larger one is my detached garage). I own the forklift, so I'm definitely keeping it!
Planning on adding a single 20A 120V circuit for lighting and exhaust fan and a couple utility outlets.
And I love the Chessie logo too!
R
RichieP_MechE
Near Pittsburgh
Day 3 progress. Ended up doing some work preparing the PVC trim boards (not shown) for painting in the morning. Got the main roof components down in the afternoon. The rake trim and high side peak are prepared but not installed yet, I want to get some paint on the structure before installing them.
R
RichieP_MechE
Near Pittsburgh
And this past weekend I got the door installed. Somehow the rough opening ended up being pretty non square, so I used the door trim to re-establish a square opening.
My Dewalt vacuum grabber left a mark on the door, will address that when I touch up the paint
Have some pretty large gaps between the door and the frame (2x4 support frame is inset by 1/2" on three sides from the plywood door panel), need to find a decent seal.
Also added the vertical trim pieces
Took my time with the squaring of the trim and building and setting the door, and that paid off as the door is nice and level and stays were you put it. Need to decide on a latching solution next. I'm not sure that I want to just use a padlock.
NightSky
Southwest OH
Could you give basic dimensions of the shed? Looks like the side walls are 12' long with 16" stud spacing on the high wall and 24" stud spacing on the low wall. Just a guess that the end walls are about 4'. How tall are the walls to the top of the rafters?
R
RichieP_MechE
Near Pittsburgh
Good guesses, everything is right here except the width which is 5'. Tall wall is about 8' and the front wall is a little over 7'. Roof pitch is 2:12. Here's a quick drawing from the model.
R
RichieP_MechE
Near Pittsburgh
Thanks.
I'm wondering what was the reason for the difference in stud spacing for the two long walls.
I wanted that side to have no visible sheathing nails. 24" spacing meant I could cover them with trim representing the vertical ribs of the boxcar at the right proportions. 16" was visually too tight. Ultimately it was a cosmetic choice.
