The internal walls need attention next.
A lot of people on this site seem to remark on how they like brick walls as an internal finish. I agree they look good but are nor as practical as insulated, smooth painted walls. The bricks that my garages are made of vary in depth slightly so there is a lot of dust caught by the small crevices. I need a space that is practical to work in so I dont mind covering the bricks with dry lining.
View media item 50343
View media item 50345
View media item 50346
I took this oportunity to prime and undercoat the skirting boards. (sorry about the poor picture quality)
View media item 50348
Its amazing how paint changes the feel of a space.
View media item 50349
Remember these trusses that came off the other roof.
View media item 50352
Time for some recycling
This is a 10 inch (250mm) Wadkin Saw (I am using imperial as primary units to describe it because that is what this Wadkin is. It dates from the 1950's so it was made before the UK went metric.) This saw is almost identical to the US made Unisaw. I am told that the main differences is that the Wadkin has the various stop and adjustment screws accessible from the outside of the Saw wheras the Unisaw has them inside. Perhaps someone who is familiar with Unisaws can comment on where the Unisaw stop screws are?
View media item 50353
Last time I was in the USA I bought a dado stack from good old Harbor Freight (some might say bad old Harbor Freight). The reasons I got it from the USA are two fold. First, dado stacks have mostly ceased to be sold in the EU because of some legislation called the Machinery Directive. Basically using a dado stack means taking off some of the guarding on a saw. Whilst this is not a problem for a home user it is an issue for industry due to the Health & Safety implications of operating machinery with guarding removed. Therefore dado stacks cant get CE marks so it is hard (but not imposible) to get them here.
The second reason is that the spindle on this saw is 5/8" (about 16mm) diameter and this is still a standard US size. So this USA blade will go onto my saw without having to use an adapter bush on the spindle like I do with other blades. Using a bush with a dado is not as straightworward as it is as using a bush with a single blade.
View media item 50354
So I made some sawdust out of the old trusses.
View media item 50355
View media item 50356
View media item 50357
View media item 50358
Because the floor is out of level I made the bench square but then made some shims to go under each leg to get the top level. You can see them in this picture near our cat who had come to inspect progress so far.
View media item 50359
View media item 50360
The thing about bench space is that it soon gets cluttered. This bench is not yet finished, I have just built the frame and put a piece of ply cut in half on the top for now but it is nice to start to have a space to work in rather than work on. The ply is a standard size sheet which is 2440mm x 1220mm which is very close to 8" x 4" so the bench is 2.44m or 8" long so it gives these pictures a sense of perspective on how big (or if you ask me, small) this space is.
View media item 50361
View media item 50362
Whilst I had the saw out I made more sawdust out of some birch ply.
View media item 50363View media item 50364View media item 50365View media item 50366
Now I need to think about power and light. Here in the Uk, electrical work has to be signed off by a competent person. For domestic work they have to be Part P Registered. The UK Building Regulations are like USA Building Codes and they are split into sectione with each section lettered. For example Part L deals with insulation and Part p is electrical installation.
Some electricians insist on doing 100% of the work themselves. However I use a guy who is able to sign off other peoples work so I do all of the first fix and he connects and test the circuits and issues the Part P Certificate. An advantage of the way that I am doing this is that everything is surface mounted so it is easy to inspect.
I have gone with Trunking and conduit because if I buried everything then it is harder to change layouts or add circuits and I am pretty sure that I will be changing layouts as the space evolves and I buy a couple more machines that are on my list of things to get. I know lots of people dont like surface mounted conduit but I dont have a problem with it in a workshop/garage context and it gives me the flexibility that I want and need.
I used HF (hgh frequency, not Harbor Freight) light fittings with daylight tubes. The HF fittings come on instantly and dont flicker if they have a fault. They also use less power for the same light output.
View media item 50367
View media item 50368
View media item 50369
