Hello all. I wanted to do a quick update for those of you still hanging around. As you know, we've temporarily suspended work on the Concrete Underground due to ....... well basically a lack of funds. I needed to free up some cash by selling our old house and now I'm looking for a bank reckless enough to finance the rest of the build.
Some of you may have looked at this project and assumed I'm a wealthy guy - some have even suggested i"m some sort of evil super villain.
Nothing could be further from the truth - on both counts. The wife and I work hard and make a good living but we're far from wealthy. This house is a major stretch at this point in our lives and I been sweating bullets over getting a new mortgage. This is especially true since, as my wife regularly reminds me, we've sold our house and are basically vagabonds. We're in a rented condo for the winter and will go back to the camper next spring.
The good news is that we've been approved for the financing subject to the appraisal. Unfortunately the appraisal is far from a lock. Comps are going to be tough to come by. Apparently not many people build high end modern concrete homes in rural Maine - Go figure.
If the deal goes through, we'll get back to work right away and try to get the place finished by next fall. If not, well I'm not really sure what plan B is.
In the meantime, I needed to get ready for cold weather. My biggest concern was keeping the various voids in the slab from filling with water, freezing and breaking my new floors all to hell.
I decided on a two pronged approach. I covered the holes with
Vycor flashing (basically strips of ice and water shield) to keep the water out. These are the 'buckets' for future floor lights.
I also tucked the Rotary in-ground lift in for the winter as well some more light buckets.
My second level of defense is in case water gets by the
Vycor. I rolled up some closed cell expansion material and stuffed it in the hole. I figure the material will displace most of the water and provide space for expansion if some does get and freezes.
To keep the expansion foam from floating out if the holes filled with water, I covered each with a cement block.
I also had to protect about a dozen block-outs for the steel columns that support the upper floors. The hole you see to the left is a ductwork penetration that goes all the way through and won't hold water.
Another concern was water getting in to buried pipe or conduit and freezing. I blew out all the ones I thought might hold water and re-taped the openings to hopefully keep water out.
I was originally concerned about leaving my non-air entrained concrete exposed to the weather but finally decided there wasn't much I could do about it. There was just no practical way to keep water from getting on the slab and freezing especially with all the pipes, conduit and rebar sticking up everywhere. The concrete was cured properly, has developed full strength and the surface is good so I'm pretty sure it will stand up.
I figured I'd throw in a couple shots of where we are in the process.
Here's the front of the house with the cantilevered master bedroom
Here's an angle you haven't seen before - from the roof of the camper
Finally here's a couple shots of the upper garage with the rain screen siding done
Well that's about it. Not much too show for the last couple months. Sorry for the long post but I wanted to keep you guys up to speed on where we're at. Figured I might as well give ya the whole picture. Oddly, one of the things I miss the most about not working on the house are the conversations with all of you.
Thanks again for your continued interest.
