Well, we're plodding along toward our next AC placement. We spent a good bit of time digging out from a weekend snowstorm yesterday and are preparing for more snow tomorrow. C'mooon spring.
Getting ready to close the Prep Kitchen wall;
Here's some more detail of the U shaped wall that houses the gas fireplace. We incorporated some reinforcing to create a beam or header over the opening.
I'm installing keyways for the cantilevered mantle and hearth that we'll place later. We'll use conduit to create sleeves for some high strength threaded rod anchors that I'll post-tension after concrete sets to pull the hearth and mantle hard against the concrete wall.
You can see the keyway for the mantle behind the rebar in the previous picture. Here's the keyway for the hearth, which will bear on the bottom of the concrete opening in between.
The AC wall is only 3 thick in front of the fireplace necessitating some tie modifications. I want to see a typical cone hole from the front so we cut a tie down and installed a piece of PVC to allow us to remove the continuous coil rod.
We also got started on the ICF walls - barely
These are a couple of our window bucks that will form our rough openings. The Advantech plywood frames will stay in place and be secured to the concrete within the ICFs via 1/2 dia anchor bolts - the bracing is designed to be removable.
These bucks also act as the bottom form of the perimeter concrete beam in the LiteDeck roof slab above.
If we get any kind of decent weather we'll get a concrete placement in before the weekend.
