I'll warn you in advance that I'm stretching for content but didn't want to go too long without an update. It's basically me and a part time electrician. He's doing rough in and I'm rubbing concrete. Here'e the finished product in the back stair hall. It didn't come out too bad.
A also had the sheet metal guys in to run the ductwork for the range hood. This is what happens when you fail to plan and the HVAC guy get's there first. I used drop in anchors into the concrete beams within the LiteDeck floor system to make sure it doesn't come crashing down on my dinner.
Started another little project. This has bugged the hell out of me since I first saw the design. The stair stringers to the second floor intrude into the ceiling below, which would have required a sloped ceiling.
It might seem like a small detail but it's the details that matter. Here's a little sketch showing what I came up with. I figured I could fab up a frame out of 3 x 3 angle to replace a section of stringer.
Here's the framing in place. Voila, a flat ceiling.
Here's a view from the front. One nice benefit was that it gave me an excuse to fire up the plasma and Mig. Had the electrician wire them up in the future shop.
The back of the frame is supported by anchors into the concrete core in the ICF wall. I still need to figure out some hanging supports for the front.
I'm using a similar technique for some cantilevered stairs to the Guest Rm.
I actually hired a local engineer to check the numbers to make sure they didn't fall off the wall. $500 later and he put less rebar in than I would have if I hadn't asked.
They'll look something like this
Here's a shot of the cut out. We'll be drilling and epoxying 4, #3 bars per tread. My engineer calculated thet we'll get 1/16" deflection and suggested I build in a corresponding pitch so the stairs end up level. Yea, like I can place concrete to a 1/16" Geez.
Now come the part where I start stretching for content. I showed you the ice breakers last week. Well, it worked. Look Ma, no ice.
One nice thing about the spring thaw are all the little streams that start flowing. We can hear this one from all over the property.
Finally let me share some shots from around the house. Once the leaves come in you won't get some of these views so now's my chance.
Well that's all I got. I'll keep you up to speed as I work my way through my current projects. The garage doors are due in a couple weeks so we'll have something that is actually garage related. Some cool details to share with them too.
