Having stripped the aprons, we're finally able to do some rough grading. I don't want the frost lifting them so I laid some rigid insulation 4' out in all directions.
The rigid will retain the natural heat from the ground and keep the frost out.
We also stripped the hearth and mantel. We still need to clean up all the concrete but it's looking pretty good.
We also had some actual garage related progress - the garage doors are in!
They are manufactured by
Raynor and consist of anodized aluminum frames with insulated glass panels. The work shop door is 9' wide;
The garage is serviced by an 18' door;
They look as good from inside;
The photos really don't do the doors justice - they are really beautiful. The glass looks mirrored but they are just tinted grey to match the rest of the glass in the house.
As I mentioned in a prior post, we converted the 9' door to a sliding configuration while maintaining the appearance of a overhead door.
If you recall, overhead door tracks would have conflicted with the bridge crane,lift and skylight. My overhead door company ordered some high strength hardware and engineered a custom set up. I'll post some details of the install when I get a chance to get some pics.
The glass paneled doors really let in some much needed natural light. The work shop really is mostly underground after all.
Here's a shot you might get a kick out of. We're playing around with some accent lighting at the cantilevered stairs. Here's a shot of lighting from below. We'd probably do three of these lights.
We've also finished up most of the odds and ends of metal framing. Here's a shot of the stairs to the second floor of the house that I modified to eliminate the sloped ceiling. Hopefully you can see what we are trying to achieve. It's interesting to note that this is a detail that consumed many hours in the planning and execution and yet when it's done, no one will ever know it's exists.
Finally please allow me to share a spring ritual that means all the more for the rough winter we just endured. The docks are in. We put them in in the pouring rain Saturday morning.
There'a actually a lot going on right now. Hopefully we're generating some momentum to push this thing through to completion. It's about time! In case you didn't notice, we recently passed the 2 year anniversary of our start. Sheesh!
