hdv32
We live over six hours away from our two adult daughters. While visiting I'm always asked if I can fix something and more often than not I don't have the tools I need to do it easily. When I know what I'll be working on I was always gathering what tools I might need into a small bag and normally forgot something. Unfortunately, neither of them have much more than basic tools on hand.
The things I tend to do are hanging ceiling fans and lights or light fixtures; changing faucets, unclogging drains, fixing Barbie Jeeps for the granddaughters, painting or flooring etc etc etc.....
After the holidays I decided to put together a bag to handle most things except painting and heavy carpentry.
Please take a look at what I have put together and let me know what I need to add or can eliminate. And yes, I took this as an opportunity to buy a few new tools.
Electrical Tools
Plug tester, Multi tester, Non contact voltage tester
Channelock lineman pliers
Channelock needle nose pliers
Channelock diagonal
Multi purpose wire strippers
General Hand Tools
Sockets - Makita 1/4” socket sets - metric & SAE, 1/4” breaker bar, 1/4” extensions, 1/4” flex ratchet
8” Crescent wrench
Ball end hex key sets - metric & SAE
Pliers - Knipex Cobra 8 inch water pump pliers, Knipex 8 inch pliers wrench and 10 inch Doyle “cobra” water pump pliers
Precision screwdriver
Klein 11 in 1 multi screwdriver
Klein 6 in 1 stubby screwdriver
Demo screwdriver
Vice grips - 6 inch needle nose and 7” standard
Combination double box end wrenches - metric & SAE
8 ounce hammer
Drill and Driver Tools
Milwaukee 1/4” impact driver
Railer Bit holders with both 1 inch and 2 inch bits selection
Countersink bit
Stepped drill bit
Malco impact / nut driver quick change handle
1/4 inch ratcheting bit wrench
1/4” impact drill bits - up to 3/8”
Measuring & Marking Tools
Center punch
Swanson speed square & small combination square
Fascap 16 foot tape measure & Bosch laser tape measure
Empire 9” level
Sharpie, Mechanical carpenter pencil
Cutting & Scraping Tools
Titan blade holder - uses metal, plastic and razor blades
Folding multi saw - uses t shank jigsaw, hacksaw and sawzall blades
Disposable large and small box cutters
Pocket Knife
Miscellaneous Tools
Small metal file and 4 way wood rasp
Hanson stud finder
Small pry bar
Paint can opener
Magnetic pickup tool
Cleaning brushes
8 ounce hammer
Wood chisel
2' metal putty knife
Pick & hook set
Chisel - 1/2 inch
Nail punches
Punch / alignment tool
Rechargeable flashlight
Pony 2 inch spring clamp
Large Consumable Items
Small spray bottle for Simple Green
WD 40 3 ounce can
Small roll of Gorilla duct tape
Masking tape
Teflon tape
Electrical tape
Shop rags and microfiber cloths
Thin mechanics gloves
Disposable gloves
Small Consumable Items
Wago wire connectors
Screws
Roll of soft wire
2 part epoxy - small tubes
Small picture hanging assortment
Superglue
Zip ties
Crimp on electrical connectors
Wire nuts
Lighter for shrinking shrink wrap
Shrink wrap
And the bag
I've got thick skin, please let me know what I'm missing or what I need to leave home.
Thanks
Electrical Tools
Channelock diagonal
General Hand Tools
8” Crescent wrench
Demo screwdriver
8 ounce hammer
Drill and Driver ToolsMilwaukee 1/4” impact driver
Countersink bit
Stepped drill bit
Center punch
Empire 9” level
Pocket Knife
Miscellaneous Tools
Hanson stud finder
Small pry bar
Paint can opener
Cleaning brushes
8 ounce hammer
Wood chisel
Pick & hook set
Chisel - 1/2 inch
Nail punches
WD 40 3 ounce can
Masking tape
Teflon tape
Electrical tape
Disposable gloves
Screws
Roll of soft wire
Superglue
Zip ties
Wire nuts
Shrink wrap
And the bag
Thanks
