The Deuce Garage
brad900
Atlanta, GA
I have garage doors. One of my coworkers cousin owns a garage door install & repair co. & hooked me up. Both doors are insulated 9 R-value with high lift tracks. I got the back wall siding up while they were installing the doors. So far a good day
brad900
Atlanta, GA
It's been raining the last 2 weekends. Had a break from the rain today & got some siding up.
brad900
Atlanta, GA
I got the 4 sides done. I started to put up the soffits, not easy to do by yourself. I had to make some L shaped jigs to hold the hardie plank once I got it up there. Then I put a 2x4 under the hardie plank so I could lift it without it breaking. The fun part is climbing the ladder with no hands & trying to slide the 12ft plank into place. :willy_nil
brad900
Atlanta, GA
I've been busy getting the electrical trench dug, hit 2 pockets of granite. Rotary hammer took care of one & the other I trenched under. Now just waiting for the electrician to pull the cable & power it up.
brad900
Atlanta, GA
Power is on. I backfilled the trench over multiple days so them rain could compact the dirt. I got the fascia and soffits primed & painted. The front battens are on.
draider
Texas
Looking good Brad! I like how it turned out with the batten strips. Nice touch!
brad900
Atlanta, GA
Its been raining alot lately so its been slow going. I have some of the siding painted, very glad to see the yellow go
brad900
Atlanta, GA
Its been awhile since I've posted. I am done painting the outside. I have all the trim up. I gut the gutters installed. I will now have to do the final grading & then the outside is done.
brad900
Atlanta, GA
I decided to clean up the garage so I can pressure wash the floor & seal the concrete next weekend. Its nice not to trip over things anymore. Its also nice to have a truck to hide all the **** in until I build some cabinets
brad900
Atlanta, GA
The pressure washing did not go as planned. I have some stains from leaves that won't come up. Also have some rust looking spots, don't know what there from.
SiGmA_X
Portland, OR
Perhaps an acid stain is in order? It would look fantastic, especially with the deuce!
vtelvr
Very nice garage/shop area. Pretty close to what I would love to have one day when I have enough space to do so. The high ceilings help with lifts...as I see you have planned. The Deuce is AWESOME. I am itching so bad for one, but just do not have the room for one! Keep up the good work!
brad900
Atlanta, GA
Thanks guys.
I thought I would put all my veh. in to see what it looked like. I still have to put in my jetski & 2 motorcycles
brad900
Atlanta, GA
Hi Guys,
I had to take some time off from working on the garage for a side project but that is over now. I started on getting the ceiling drywall up, not so bad with the scissor lift. The hardest part was getting the 5/8 x 12 drywall out of the deuce on the scissor lift. I have 7 of the 9 lights up, some of the outlets in & some of the insulation in.
brad900
Atlanta, GA
Well during construction leafs stained my garage floor & scrubbing them out wasn't working so well, there was only one thing to do. Polished concrete
brad900
Atlanta, GA
I have done a lot since my last post. I got all the wiring done, insulation & drywall hung. I have been taping & mudding for a long time. Its a lot to handle for 1 person only working on some weekends. Also my lift came in:rocker:
brad900
Atlanta, GA
I got the walls & ceiling painted, lights up, ceiling fans up, mini split in, lift in & blown in insulation it the attic. Then I noticed that after I did the blown in insulation that some of the tape joints on the ceiling have cracked from me walking on the trusses. I had to take a break after seeing the cracks because I spent so much time doing the drywall & it's going to be a pain fixing them with the lift up.
pigag2
Ont., Canada
Love your floors. Is it a DIY job or did you hire? After they were polished, what type of sealer did you use?
brad900
Atlanta, GA
I hired out the floor after looking in too how much it would cost just for me to rent the equipment. It took him 2 long days to do it so I'm glad I hired it out. The sealer was put in during the polishing so I don't remember what he used. I did look it up back then & it was expensive
