Bellydump1974
- Joined
- Jul 9, 2016
- Messages
- 7
Very impressed so far on the quick flow of information provided here by the site patronage.i use a extended reach push pull feeder for aluminum welding powered by a mm 200 powersource. I run the control wires thru the lead socket on the welder which works fine other than the welder can't tell anythings changed so I need to release drive roller or hard wire will run out all the time the push pull feeder's trigger is pulled.i was told when I bought the feeder it won't work to plug control wire into the spool gun receptacle on the welder. I guess I believed this so I never tried but it never made sense why it wouldn't work. I hate to rig up something to try it in case some unknown factors might damage the circuitry. But I've been tempted. Any ideas as to what the difference between a spool gun and a xr feeder is to an old mm 200?
