I have 2, 12-inch steel trailer wheels. They have very cheap white powder coating on them (China) that has become discolored, a sort of yellow-beige color. I plan to remove the powder coat and have them redone in satin black. The easiest method for removing the coating appears to be "vapor Blasting" but the quote I got was far too high. The second best technique I read about is maybe gasket remover spray, I'm going to try that first. Finally, media blasting them is the other alternative, but I have read that it requires robust media, a lot of pressure, and is time-consuming.
For anyone that has removed powder coating from steel before, what method did you use and how did it work out for you?
Thanks!
Thanks!
