The engine is the compressor.
HoosierBuddy
Southern Indiana
Guys,
Thought a few of you might be interested in this old gasoline powered air compressor. It’s not exactly correct to call these old Grimmer-Schmidt compressors “engine driven” because the engine is part of the compressor and they share the same crankshaft.
Basically this is a Ford 302 engine that runs on 4 cylinders and the remaining 4 cylinders pump air. The ingenious bit, in my opinion, is the automatic throttle control that revs up the engine as the air pressure in the air tank is pulled down by attached equipment such as a jackhammer, sandblaster, etc.
OccupantRJ
Eastern North Carolina
Here is a monoblock compressor thread that I started when I had one.
finn
The UP, God's country
There were flathead Ford based air compressors like that in the thirties, and four cylinder Model A engine air compressors before that.
Schram, or something like that comes to mind.
460 Fords were used well into the nineties.
Wrench97
Southeastern Pa
Many years ago when I was in high school I worked for a company in West Chester Pa that repaired Schramm air compressors the early ones had flat head Ford V8's converted, 6 cylinder OHV Fords and IH 6 Cylinders converted to 3 running 3 compressing. They basically used what ever they could get cheapest, there were some with their own 4 cylinder gas engines driving a 4 cylinder compressor to Wisconsin air cooled conversion, any industrial engine could have been used. Schramm in the 70's started moving toward drill rigs and by the mid 80's divested themselves of tow behind and stationary compressor rigs.
Ultradog MN
Twin Cities
Guys,
I saw a similar set up years ago. I want to say It was a Pontiac or Olds engine - can't remember now. Pretty clever, and cool.
H
HoosierBuddy
Southern Indiana
One issue with the monoblock is the extra heat in the output air from both compressing the air and the heat from the running portion of the engine.
We’ve had this one at my work for over 25 years. It doesn’t get used a lot but is a good machine. Parts at this point for the compressor side are unobtainable. The biggest issue we ran into many years ago was using it to run a sandblaster where a hose was supplied to the helmet of the guy blasting to keep him cool and prevent fogging. Can’t do that! He was breathing engine exhaust.
nadogail
Coronado, CA
The US Navy had some tractors with Schram comressors, I drove one to a jobsite in 1971.
Sumboodie
AK
One of the shops at work has 454 vac pumps on huge vac trailers. Deere powered hydraulic system that turns a Chev 454 with special heads.
They send the blocks out to some race shop for rebuild. Surprising there aren't a ton of engine machine shops around anymore, and less that are well versed on BBCs.
I forget the brand now. We recently switched them to Delo 100 40wt, as Delo 400 15w40 XLE was causing fairly low life cycles.
matt_i
SE Michigan
I believe Farmall had a similar kit for inflating these new-fangled rubber tires starting in the late 1930s, it screwed into a spark plug hole of your choice with a check valve. My concern would be that unlike the compressor V8 classic design, the cylinder in question was not isolated from the atomized fuel supply (!)
kumquat
North of Montana aka Saskatchewan, Canada
That was the only air compressor ob our farm when I was young.
nadogail
Coronado, CA
Recalling a memory from the mid 1950’s the Automotive Machine shop I was working in was called upon to rebuild an engine/ compressor that had 6 cylinders. 4 were a gas engine and 2 larger ones were compressor. To the best of my recollection it was a LeRoi
