Toolhunter
I told a friend I could use a small trailer to haul my quad and my dirtbike around. Well the friend is moving and says I got one you can have...Im always up for a challenge lol
This is the trailer I have taken the axle off in this pic, old fire gloves work great for welding
Rear shackle mount other side was off the frame, The rust is not that bad pic makes it look worse, I gave my friend some **** for his flux core popcorn he made lol all are going to be ground down and re welded, I have a vintage sears arc welder that I bought for $30 built a home made rod dryer box and have been practicing.
heres some 1/8" 6011 at about the 95 amp setting
Ok so heres the plan The dimensions right now are 4' wide and 5' long and the tongue is about 5' from where it meets the trailer to make the 60/40 I would like to add 2' to the rear and 3' to the front and also add 1' to each side of the trailer and put a railing all the way around drive over fenders would be on the inside of the railing. I called a local steel place and they wanted $130 for a 24' 2x2x3/16 I know a local place that builds signs for the highway will be checking to see if i cant buy some of their scrap stock. but until i source my metal grinding down the old welds and re welding and repacking bearings, replacing and yes this is all fun to me lol.
