The funky ratchet
ClineWrench
So, I spotted a completely funky ratchet that I couldn't help but pick up. It's branded as a Popular Medhanics ratchet, and I assume some major tool company made it.
That said, it's the strangest ratchet I've ever seen. It doesn't operate by swinging the handle, it operates by twisting the t handle at the end! What's more is that the back of the head is completely smooth, and the switch is just below the face.
So that's my funky ratchet. Let the schooling begin on what the heck Popular Mechanics was thinking when they built this thing.
quattroJoe
FL
I think the idea is to use it in places where there is no room to swing a ratchet or wrench.
Gmonkee
I have another version where a regular style handle spins where the T handle was. For my hands it helps make up for where l lost dexterity.
There is little love for those on the tool forums but mine is the only l use anymore.
mossyboy6
St. Pete, FL
They actually come in really handy sometimes, but not handy enough to own one.
It saved my *** once in a parking lot, but I haven't found a use for one since.
C
ClineWrench
Great info and perspectives guys. It's certainly an odd ratchet, and I have to admit, I kinda like it.
The price was right...free. So I suppose I'll keep it around for awhile.
warweapon762
I prefer the Stanley Rotator, but these do come in handy. Newer models have a much lower profile that is considerably better than the older ones, but good luck finding anything that isn't an import of some sort now.
JDon99
Desoto, MO
I've also used the Stanley Rotator(or one of the rebrands from the same manufacturer). Works great in certain situation where you don't have the room to get much of a swing, especially on a longer threaded bolt. It's worth keeping one around for those "just in case" situations.
Tim37
Popular mechanics was a house brand for Walmart supriseingly they werent bad they weren't great but along the same lines as stanley. I have the same ratchet the problem is its so bulky its hard to get in a tight spot where its intended to be used
twertsy
Reedville, VA
I believe mine's a Kobalt? Interesting side note, a gentleman in my neighbor shop has designed / applied for patent/patent pending on a ratchet whose action is engaged by "pumping" the ratchet handle up and down, no lateral movement required at all. Pretty cool design (I've seen all the schematics and even 3D printed him some prototype parts) even though I've mentioned to him I'm not sure how much it'd be called for in everyday use, particularly where torque is required??
twertsy
Reedville, VA
Now that would be interesting to see Twertsy. I can see practical applications for a pump style ratchet.
Not a bad idea at all.
Really? I still can't think of a place I'd use it on an old car where I wouldn't just grab my Kobalt and "turn" the handle rather than pumping it? I'd be interested in hearing where you could see it being the "go to" solution?
EDIT: don't get me wrong, I think it's "cool" and all, and I'd probably own one if for no other reason than a friend invented it..........or that I'm simply a tool *****.
iajonesy
Iowa
I have a Blackhawk ratchet that operates in a similar way. You can twist the handle to rotate the socket or use as a regular ratchet. They must have stolen the idea from P/M.
Mike
farmall57
I have the Blackhawk version as well, and use it a lot. One thing I would really like is a lock to keep the handle from rotating when you want to use it as a normal ratchet.
Milton Shaw
These are real handy for sparkplugs on older engines like a sb chevy or ford where the plugs were below the exhaust manifold and not a lot of room to swing a normal ratchet. AC/Delco used to sell a tool like that just for this application. Lifesaver when you need it.
Scimmia
In any situation where I could see this being handy, I would rather just use a pneumatic ratchet
