ll1l2l1l2lll
- Joined
- Dec 10, 2024
- Messages
- 1
Very beautiful home and garage. I grew up in the San Gabriel area and was always enjoyed the peacocks.
No, but he does have the CA Proposition 65 warning about concrete anchors causing childhood cancer, peridontitus, male pattern baldness, scurvy, and erectile dysfunction prominently displayed as required by state law.And y’all got those posts anchored into the concrete patio, right? Right? Oh….
Still only one. I think I'm gonna leave it that way permanently. Give the trolls something consistent to comment about! LolAnd y’all got those posts anchored into the concrete patio, right? Right? Oh….
Thank you for the kind words. We were very blessed to get this house when we did - after retiring and right when the COVID-19 pandemic was happening. We couldn't buy it back from ourselves at this point.Very beautiful home and garage. I grew up in the San Gabriel area and was always enjoyed the peacocks.
Just the one use so far but I'm impressed something so cheap and Chinesey works so well! Maybe it'll fall apart but even if it does the $30 to fix the table leg was cheaper than ordering a replacement leg. Any use I get out of it after this is a bonus.I now have the same welder. I recently chucked some stuff that would have benefitted from it. I'm ready for next time.
I almost always setup both of them. Came in handy when edge banding 8' long melamine pieces. I could clamp them across both tables on edge and they were rock solid.Just the one use so far but I'm impressed something so cheap and Chinesey works so well! Maybe it'll fall apart but even if it does the $30 to fix the table leg was cheaper than ordering a replacement leg. Any use I get out of it after this is a bonus.
rharman, I hadn't thought of a 2nd Keter table but that's a good idea. Much less utility provided by sawhorses and the Keters fold up so neatly too.
Cyanoacrylate is brittle and will break again. I would use something like this which is a structural adhesive likeOn a different subject, I posted THIS on an older thread about plastic repair:
I searched for "Plastic Repairs" and plastic "welders" came up. I was hoping to find info/advice on Super Glue + baking soda repairs. I have a Keter folding work table leg that broke. The legs are aluminum but slide into a plastic sleeve that mounts and is the pivot on the table. The plastic broke RIGHT AT the joint between sleeve and pivot portion.
But metal + plastic weld fixes look superior to an epoxy or a cyanoacrylate/baking soda fix. Any experiences to relate? Here's a close up picture of the break and the type of work table this is part of.
As you can see see, the fit is tight. Almost unnoticeable when I hold the parts together. I'm thinking maybe use super glue or two part epoxy between the two parts, then after it dries plastic weld the joint with metal mesh or staples to reinforce the repaired joint.
I used a JB Weld clear two part epoxy to initially hold the two parts together but it isn't labeled "Plastic Bonder". Then the plastic welder to embed metal staples to physically reinforce the joint. I cut off the stubs and sanded a little.Cyanoacrylate is brittle and will break again. I would use something like this which is a structural adhesive like
Plexus® MA310 Adhesive | U.S. Plastic Corp.
The solvent is a two-part methacrylate adhesive designed for structural bonding of thermoplastic, metal, and composite assemblies. It is ...www.usplastic.com
or![]()
Ha! Hardly "expert". I hope my posts haven't conveyed that I think I am! (Apologies in advance for the long post - old man talk!)So I'm getting that you're now an expert on sprinkler systems. Seeing as I need to redo all of my front lawn, how much will you charge to come here and do a system?![]()
The last line lets me know you got the intent of my poke.Ha! Hardly "expert". I hope my posts haven't conveyed that I think I am! (Apologies in advance for the long post - old man talk!)
But if you're offering airfare and hotel to Michigan, I'm retired. I've got nothing else to do!! Ha ha.
Thanks!@Dan in Pasadena - This popped up in an email I received today. Might be helpful to you.
7 Mistakes That Are Keeping Your Hydrangeas From Thriving
Hydrangeas are a pretty hardy garden shrub, but a few common mistakes in hydrangea care can lead to stunted growth or a lack of blooms. Encourage your hydrangea bush to thrive by avoiding these common issues.www.realsimple.com
That's pretty slow set, like decades. It's more a thread lube and thread gap filler under high clamping pressure kind of thing.Hmmm.... I wonder if RectorSeal #5 would work for that?
Those look promising BUT I wonder how effective they would be on tubing that’s been out there for years and does have much elasticity anymore?They sell these little stainless wire clamps for funny pipe and other drip water spaghetti lines. It's amazing how well they work.
These particular ones are for 1/4 inch but there are plenty of similar ones in different sizes.
No pressure reduction valve. In the pic above it’s connected directly to a 1/2” Schedule 40 pvc elbow. That pipe goes back to the manifold.Does the pipe to the drip irrigation have a pressure reducing valve in the line? If not, you may never get the leaks fixed. Search for drip irrigation PRVs to find what is needed to reduce pressure to the drip system, should help greatly if they aren't already there. Drip systems use a lower pressure than typical sprinklers.
Or, a light smear of silicone on the barb before sliding the pipe on. Let it cure a bit after clamping and before applying pressure.
I'll agree there. Anything taper threaded, it rocks. Hoses ain't real plumbing.Yeah, I know it's slow setting. That's why my question was more of a musing than a recommendation.
For what little plumbing I do these days, I have had good success with it.
^^^^ The most pertinent statement of all the talk we've been having.......Hoses ain't real plumbing.
