The replacement RV door window arrived today. It's going back tomorrow!
Instead of screws joining the inner & outer window frames. The geniuses who designed this decided to use plastic tabs on each frame that interlock. Oh, but that wasn't unnecessary enough so they used a combo of square tabs and round tabs - why? Then it's impossible to align these tabs as they disappear into the door and the glass is NOT HELD IN POSITION IN ANY WAY. You'd think it would be held in place BY BEING contained in a space the size OF the glass OR in place by some sticky mastic.
Nope, not held in place. You hold it in place by hand because if you let go it will fall out of position OR onto the ground and break. The instructions tell you to have a 2nd person hold the outer frame with the glass in it while the person trying to engage the inside frame HAMMERS IT INTO PLACE with a rubber mallet and wood block! Yeah, it actually instructs to do that.
What an TOTAL *************. Oh and all the reviews say how EASY it is to install. Total ****, totally fake reviews. I'm replacing with the exact same frames it came with - should have done to begin with - using screws and butyl tape that holds the glass in place. Rant over.
