G0555 Bandsaw.
PASS with flying colors. Widely acknowledged by the woodies as being a great bang-for-the-buck buy. Has won several awards in the wood magazines. I have no complaints about mine; I did buy the riser block for it. Sweet machine for not much coinage. You do need to replace the blade it comes with.
G0463 Small Mill. First attempt
FAIL and then second attempt
PASS. First one I got was badly out of tram, and there was a curved dip in the table like a polishing machine had spun down on it. It messed with my ability to measure tram. After messing with it for a month, I contacted Griz, who cheerfully said, "Send it back!" So I did, and they sent me a second one that was trammed, true, and plumb within a couple thousandths. A little shimming here and there and it's now quite accurate. Can't imagine life without a mill, now that I own one. I can keep tolerances to a couple thousandths, generally.
Dial height gauge, marginal
FAIL. Not anywhere near the Starrett we use at the school. Quite wasteful of space because there's a lot of metal at the top that isn't useable for measuring...it's taller than you'd like for the capacity it gives. First one returned due to stiffness; second one returned due to stripped fine adjust nut.
Oil can. Looks nice but miserable
FAIL. Doesn't squirt, and leaks out the bottom. So it dribbles where you don't want it, and doesn't where you do.
Granite surface plate.
PASS but how can you screw these up? OK, to be honest, I have not actually measured the surface on it, they claim .0001 bi-dimensional accuracy, so maybe it's a fail and I just don't know. So inexpensive they're almost disposable. Amazingly heavy and accurate for something so cheap.
Slitting saws. Another miserable
FAIL, the hole is off-center! Diameter measures .010 out of round! So only one side of teeth contacts the work at first.
R8 Collets.
PASS. Very pleased, and relatively inexpensive.
