The Harbor Freight PASS/FAIL Thread...
skulldrinker
Bolingbrook, IL
3/4" to 1/2" black impact adapter - major fail!
I used that same one with my 3/4 impact gun and it has held up. Maybe when using an impact gun different forces are applied on it. Taking off some leaf spring hangers I stalled the 3/4 gun so the adapter was taking on a lot of torque. Maybe i got a good one. :)
diggerrick
I used the 3/4"F - 1/2"M adapter and it didn't break. It did round off the nut, though, and I had to cut it off anyway.
y5e06
Austin, TX
i have been contemplating getting one of these for a new welder i will be picking up. I don't think i want to spend the time fab'ing up a new cart from scratch.
although not the exact same, i do already have one of the stamped sheet welding carts from one of the big two. One thing you can do to greatly increase the strength is to go ahead and weld up the joints instead of just relying on the bolts. it makes a significant improvement in the rigidity of it... and if you own this you most certainly own a welder too....
Welding Cart - Pass
http://www.harborfreight.com/welding-cart-90305.html
I just got this yesterday, and while I don't do a lot of welding (just household stuff), for 35 bucks with a coupon you can't beat it. Seems to be adequately built for garage/home owner use.
Provincial
Near Salem, OR
I have had one of these HF 90305 carts for a few years. I put larger, pneumatic wheels/tires on it because I move it across a gravel parking lot between shops. I also widened the rear axle for more stability in the gravel. The basic cart is sound, and I have had no problems with it.
I bolted mine together and have had no problems with loose joints.
acdc73
My 3/4-1/2" impact stepdown which I broke cost me $18 or so back a few years. That said, I learned its limits and don't push them.
In your case, the $1.66 item (3 piece kit for $5 if you didn't use a 20% off coupon making it just $4) failed at what you consider to be very low torque. You threw it away in the fit of rage, understood. Instead, next time, get them to give you another and don't break it or simply just return it for a full refund.
That way, you get your money back and aren't so **** hurt over it the $1.66 expense.
LOL :lol_hitti
signcrafter
3 piece set
I was using it with a 3/4 x 24" breaker bar and 1/2" dirve socket to take off my porsche axle nut - twisted the adapter right off.
got out my 1/2" S-O 18" breaker bar and a floor jack handle as an extension, and took the nut right off, so it wasn't THAT tight.
I'm not an engineer but from what I understand the black stuff made for impacts is made of a metal for impacts. Chrome is made from a metal for hand tools. One is softer and one is harder. In other words a black impact adapter shouldn't have been used with a breaker bar. At least that's what I have come to understand. Different metals have different properties and are treated to different hardness.
sjlee
WI
Right.
http://www.ehow.com/facts_7601292_impact-socket-vs-normal-socket.html
http://www.hotbikeweb.com/tech/1001_hbkp_impact_vs_chrome_sockets/
Plus... "breaker bar + adapter + socket" will always be weaker than "breaker bar + socket".
trainman1385
Utah
fail -customer service
Purchased item available on line on closeout was not notified item was no longer available, only found out when called to see if i could get accurate tracking number as they used the same tracking number for two different shipping order #'s. They didn't even notify that they wouldn't be shipping me the item, Purchased woodworkers vise from northern tool today should have it in a week
ChevyEFI
Phoenix, AZ
3 piece set
Any step-down adapter is going to fail before the other involved pieces. It's just the nature of the design and it would have happened to a chrome adapter, brand-regardless. The 1/2" breaker bar should have been used first, given socket availability.
cheechi
Triad, NC
The welding cart you guys are talking about. I bought one, haven't put it together yet. When I was buying mine, someone else was returning theirs for replacement complaining it was completely rusted through on several parts.
I checked mine as well as I felt like doing and doesn't appear to be rusty.
Danglerb
SoCal
Same here, I ordered the Dual Action polisher and two each of the three pads to go with it.
No email nothing, but the DA was put on back order, and pads refunded.
When I called the human I reached pretty quickly on the phone cheerfully sorted it out, but the automated system stinks.
subarub4
Connecticut
66150 hydraulic crimper = major PASS. Used the heck out of it over the past few days making battery charger cords, cables etc.. for my electric dragster. Worked perfectly. WAY better than the old hammer style crimpers.
Nice, I need to get one of these but stuff the price HF has it for is a bit more then I want to spend but it's better then the hammer type.
stricht8
Mine is a complete rust-bucket. The powercoat peeled off in 1 foot sheets to reveal heavily rusted metal underneath. Haven't gotten around to returning it yet.
GDVink
HF Jigsaw with Laser/LED guide: fail
This review is for an HF orbital jigsaw with LED/laser illumination, item 68821, which apparently they are no longer selling. However, I am writing this review because the saw is almost identical to a current model, item 69077.
The main difference between the saws is that mine had a combination laser/LED light. The current model scraps the LED light and keeps the laser, which is too bad (details below).
I bought this to replace a $30 Skil saw that worked pretty well for several years but eventually the automatic blade holder would barely hold the blades, even after lubricating, and finally disintegrated into several pieces.
I've owned the HF saw a couple of months, and I really wanted to like it, but I don't. My comments:
Pluses:
--it's a pretty smooth, powerful motor (6.5 amps) but makes for a heavy saw (6.3 pounds).
--the LED light that shines on the blade is helpful (except that the newer model no longer has the LED light -- see below re the laser).
--the holder on the power cord for the hex bit used to adjust the sole plate is a good idea
--the no-tools blade holder seems heavy duty and well designed. (It uses T shank bits -- also sold by HF -- which are more expensive than the universal shank, but actually stay in the saw.)
--one-off button and speed control roller are convenient. Saw also can be locked "on."
Minuses:
--the laser guide would be great if it weren't totally inaccurate. As far as I can tell, it can't be adjusted.
--the cutting guide on the front of the metal sole plate is only somewhat accurate.
--three orbital settings seem like overkill, plus I doubt this number of choices enhances reliability.
--the sole plate is attached by one small hex bolt. While it can be infinitely adjusted to 45 degrees left or right, frequent adjustment will wear out the threads (a frequent achilles heel for the crapola pot metal underpinnings used in many HF tools).
--the clear front blade shield doesn't flip up quite right ... the dimensions are slightly off.
--you can only use the laser or the LED, not both at once. But since the laser is worthless, no biggie. Except that the new version of this saw doesn't have the LED light (!).
--you have to remember to turn the laser/LED on or off -- it doesn't switch on or off with the tool. Think rechargeable batteries.
--although this saw is billed (in the owner's manual) as part of the Chicago Electric "professional" series, the warranty is the same skimpy 90 days.
--I couldn't tell any difference with the blower turned on or off -- either way, the saw seemed to mostly blow the sawdust away. I didn't try plugging it into a vacuum cleaner.
So ... it seems strange that HF deleted the most useful part of this saw, the LED light, in view of the worthlessness of the laser.
The list price of this saw is $60 and of course there are many ways to get it cheaper. On the other hand, Home Depot is selling a Ryobit jigsaw, with LED light, for $30. It uses T bits, has adjustable orbital settings and comes with a three year warranty. The Home Depot saw is only 4.8 amps, vs the claimed 6.5 amps for the HF saw, but I strongly suspect the HF number is BS -- to get that power from DeWalt or Makita, you're talking $120 to $150.
In summary, I thought HF having a "pro" series of electric power tools would be a great idea -- better quality at a higher price. Instead, you're getting more power and features but the same ho-hum quality. When this thing fails, I'll go for a Ryobi, or maybe move up a step to the $100 range.
IONH
Central Massachusetts
Can you take some pictures before returning it so others can see what to look for when purchasing theirs. Perhaps they can peek in the box before paying and swap it for a better one.
GDVink
Re: HF Jigsaw with Laser/LED guide: fail
May I ask what the item/model number is?
re the HF jigsaw review a couple of posts back, the model number of my saw is item 68821. I have edited my review to clarify and make a correction re warranty length.
NoNN37
So-CAL
3/8" Heavy Duty Flexible Ratchet Pittsburgh - Item#96369
PASS
http://www.harborfreight.com/3-8-eighth-inch-heavy-duty-flexible-ratchet-96369.html
It's really good deal at 13.00. Fine tooth and quick release. Its good for getting into tight spaces. The joints seemed to loose for me at first, can be tightened with the hex screw.
Recently I removed to middle section to make it a stubby. Comparable to the kobalt.
carhouse
Alabama USA
Question about the warranty process.
I am new to buying garbage at Harbor Frieght :)
Hand tools that have lifetime warranty can you bring them to a store or is their warranty process only through the mail?
I tried searching with no sucess
Thanks
The Lazy Destroyer
Woodstock GA
Low Profile Floor Jack with Rapid Pump®, 2.5 Ton Heavy Duty Steel
Item # 68049
Link
PASS
I've been using cheap basic jacks for as long as I can remember. Got this and for $70 (w/ coupon) was really impressed. For once I don't have to use anything under the jack on my Racedeck because the casters on this are pretty wide. Goes up to 20" which is nice.
It's a pretty heavy unit though. It makes my old jack look like a toy! Might pick up one of their aluminum jacks for the track as this one is a bit too heavy to just toss in the car.
cheechi
Triad, NC
Need to add a Ball Peen Hammer to my school toolbox for working on front ends and it needs to be inexpensive. How are the HF Ball Peen Hammers? I was thinking of this 32 oz'er.
http://www.harborfreight.com/32-oz-ball-pein-hammer-69012.html
From all the pics of their hammers the heads seem to not be centered on the handles. I think my Craftsmans are. Is there a difference?
I can make a suggestion that most people don't hammer 'on center' so, so long as you can aim it, I wouldn't worry too much about it.
greasemonkey44
memphis
i have one; i used it for about a year til i got into dead blow ball peins
it was decent; the balance was a bit off; one side of the head was heavier than the other:dunno:
but it served its purpose just fine
unlike a minisledge i got from there, face wasnt milled flat ...... and the handle snapped when i over stucked a plastic felling wedge
Provincial
Near Salem, OR
Air Needle Scalers:
I have both of the HF needle scalers. I bought the large one (#1108) first, and it is useful on even tough jobs. I removed heavy (3/8" thick) scale in the interior of a cast iron rendering kettle with this tool and it performed very well. I used it for cleaning up weld slag for years, but bought the smaller model (#96997) because it is much handier, and the added power of the large one is not needed for slag removal. The small model gets into much tighter areas and is much easier to handle.
Play with your air pressure to adjust the impact of the needles. Slag from stick welding takes very little impact to break up, and the lower pressure makes it less likely to peen visible dimples in the weld bead. Heavy scale needs as much power as possible, since the rust is flexible and absorbs much of the blow.
I think both the HF scalers are good for home use, and occasional commercial use. I would not recommend them for heavy commercial use. HF sells replacement needles for both models, but the needles hold up very well if you don't use 150 lbs. of air pressure! They hold up OK even at that pressure.
subarub4
Connecticut
Thanks
Bring it to the store
baldredhead
sillycone valley, ca
Portable Pocket Hole Jig
item 96264
Pass for sure.
easy to set up as pictured. it also has a mode where it'd used without the base plate that i did not have a need for on the project i was working on.
the screws it comes with even work well
word of caution: if you are buying it at a store, check to be certain that the required drill is in the box. in my area the store closest to me has had several boxes violated to steal the bit, and it is not available separately.
no brainer mod: drill a new set of holes for the clamp mechanism to allow thicker material to fit in with the base plate setup.
IONH
item 96264
Pass for sure.
I also give that setup a PASS. I used it for a few small projects and it works great. I hold the jig against the wood with my hand and drill slowly. I've used it enough to order a box of screws for 3/4" thick material.
creativecars
Indiana- where horse and buggies still roam
subarub4
Connecticut
Anyone try out the 4000 Watts Max/3200 generator? Looking to grab one of these in the next few weeks I have a coupon for it that's good until March for $249 should I get the warranty on it?
I need it to use it to run the small 10 gal air compressor
dodge610
North Canton Ohio
Both of the HF torch sets have pretty good review on their site. Do any of you have personal reviews? Are they copies of what brand?
I am looking at the 98958
http://www.harborfreight.com/oxygen-and-acetylene-welding-kit-98958.html
and the 92496 Industrial
http://www.harborfreight.com/industrial-oxy-acetylene-welding-outfit-92496.html
What is the difference between them?
Thanks...
You will be much happier with the industrial kit I use to sell welding supplies for years. The bigger gauges and torch will definetly be a plus for you. Going that route to cut smaller things just use a smaller tip in the torch.:D
rslaback
Westcentral Wisconsin
Thanks...
I was looking for a torch to have in my garage and I decided to go with the portable unit from Northern Tool (link). It has decent reviews, free ship to store and was cheaper than the Harbor Freight version (especially after the Northern tool code. And I own the tanks.
creativecars
The link you added says cylinders not included, do you mean you own other tanks? I am looking for a full size set. Thanks
dodge610
North Canton Ohio
creative cars very few sets come with tanks if they do they are the mini tanks that you will spend more time getting filled than you do cutting or brazing. The tanks you will have to get at a welding supply house.
kapster
Wooster, Ohio
Thanks...
Both of those are copies of victor torches. I was in the market a year ago for torches and my local weld shop was selling victor torch sets for 200 on sale. The victors are made in Mexico and the harbor fright china. I believe tips interchange. And the victor had the new style Gage's so I went with it.
My dad has the harbor freight torches and they've been fine except the hoses cracked pretty quick after.
creativecars
Both kits are on sale for 130 and 200. Is one a better copy than the other. I dont mind the extra 70 if there is a difference in quality or work that it will do.
