The Harbor Freight PASS/FAIL Thread...
AbitNutz
Pass...Quality construction, very complete set. Only gotta use it a couple times before my son robbed it from me. He's a tool abuser and so far its been pretty darn good he says.
Agreed. As good as the free rental from Advance, which is 12, miles away.
signcrafter
How come that HF brake kit has so many adapters compared to all the other kits the other major brands sell like snap on, mac, matco, lisle, etc. They all have 5-6 adapters and the HF kit has 14-15?
fsdogwood
RTP, NC
for pushing/winding back brake caliper pistons, more specifically pistons on rear calipers of vehicles with electronic or non drum handbrake systems.]
just ordered a similar kit on ebay £14/$21
what's the item #? Is this the one?
http://www.harborfreight.com/18-piece-disc-brake-pad-and-caliper-service-tool-kit-69053.html
Is this the name? "18 Piece Disc Brake Pad and Caliper Service Tool Kit "
(without a number or name, it's hard to search for, thus negate the usefulness of this thread)
Regards
fourtythree
WV
Different adapters for different car brands.
signcrafter
I fully understand that. My question was why all the major truck kits only come with 5-6 different adapters and the HF kit comes with 15 or so adapters? Does the HF kit cover more vehicles then snap on, mac, matco, etc.?
Haveblue
kansas
^^^^ I need to get that set! All I have Is a cheap "cube" type socket. This would work way better, as it compresses the piston as you turn it.
AbitNutz
Oddly enough, a truck was not the first place I ran into screw-in pistons. I knew a woman that had a Saab 900. The front brake calipers had them. So there are a myriad of oddball calipers that you may run into.
skulldrinker
Bolingbrook, IL
I think what he meant by "truck kit" was the kits that are sold on the tools truck example snap on truck. Their kits only include 4 or 5 pieces.
ssentt
Iowa
That brake pad caliper service tool kit is still on sale for $40. I got mine about 3 wks ago for that price.
Picked up this creeper with super coupon for $20 at same time. Salemans said I could use Feb coupon ad when I was there in March. Good deal!
Pass...durable, low to the ground, the casters roll/turn fine, but they aren't great. My kids abused it for a few days in the basement sholving each other around before it made out it to the garage.
AV tinker er
SoCal
How about harbor freights large tool boxes anybody have any luck with em?
A quick search of the forum will reveal that the US General boxes are very popular here. Watch for a coupon and enjoy.
I would look up Steevo's work bench thread using several of the 44" chests.
subarub4
Connecticut
I have that creeper works well so far made good use of it when taking out and putting the transmission back in the Subaru.
Took a little time to get used to it because the driveway has a slight incline and I kept rolling down.
cheechi
Triad, NC
'vibration reducing' glove, 95584/95585
Pass, they do a good job on the chainsaw, blower, recip saw. However they do get yellow die on your hand after a day wearing them. It washes out with regular hand soap.
Pruning blade (either 68946 or 68040 already threw out the packaging)
Pass. They don't do any better or worse than name brand. They bend the same annoying way, they bend back the same way too. lasted about an hour of running time, pretty much all continuous. That's pretty good for recip saw blades. I hate having to spend a lot on the long blades I know will bend or break more easily.
gel knee pads 68124
Pass. they work at least as well as others. saved my knees in gravel. i'm not fond of knee pads in general, pants bunch up in the back of my knees, these are the same.
SAE Ratcheting wrenches 96654
Mostly pass; not idiot proof
The ratcheting on them is fine. The wrenches are sufficiently hard to loosen stubborn bolts. Pictured are 6 wrenches I used to change the brakes on my parents' car. of them, the 9/16 was the most heavily used and the most stubborn of all the bolts. My brother needed a reminder about which direction to go. He stripped a bolt and in the process notched the open end on my 3/4 wrench. HF swapped it without issue, but I'm sure most of you are thinking 'my wrench wouldn't notch so easily' which is fair. These were the ones I had packed, normally I would have used my regular combo wrenches.
I took a few photos so you can see it had 4 notches, and to compare to the others which were all fine.
celticbhoy
24" 1/2 drive breaker bar.... Not only is this a pass, but for $12 it's an absolute steal.
3 ton rapid pump low profile jack... Pass. Awesome jack for only $70.
Brass centre punch... fail. Worked twice and then the internals broke.
MechanicNamedJohn
I love these they are my new go to extensions hopefully they hold up with use
They are good, but you need to periodically tighten the hex screw on the release/retaining collar. I use them a lot and one came out; no big deal, I found the screw and put everything back together, but I spent 10+ plus minutes trying to find it. Or, you could try Loctite.
IONH
Central Massachusetts
Just ran across another HF Review forum that may be of interest.
http://hfreviews.com/
That was introduced to us here on this board (or to me at least) back a year or so before HF had reviews on their own site. I contributed to HFReviews many times back then. Now I rely on the HF site itself as I have not heard of them pruning negative reviews.
Plus the part number is right there.
silviaboy89
GEORGIA!
i guess ill add to the list
http://www.harborfreight.com/4-piece-pick-and-hook-set-66836.html-PASS
these are great to undo plugs or remove small o-ring/seals
http://www.harborfreight.com/8-piece-professional-screwdriver-set-94607.html-PASS
love these. they are great really comfortable nice tips also.
http://www.harborfreight.com/4-piece-heavy-duty-pry-bar-set-69281.html-PASS
these are great i used to use flat-head screwdrivers as pry-bars not anymore flex a little but not to much. also look for the Taiwan onew they are better .
http://www.harborfreight.com/1-4-quarter-inch-18-volt-cordless-impact-driver-67028.html-PASS
used mostly as a mini impact on cars pretty strong no problems.
http://www.harborfreight.com/7-variable-speed-polishersander-69474-8790.html-PASS
pretty good gets the job done. i need to buy a better backing plate the one that came with it is kinda warped.
jeffk14
GA
pretty good gets the job done. i need to buy a better backing plate the one that came with it is kinda wrapped.
All your links are broken...:dunno:
skulldrinker
Bolingbrook, IL
Going through the site I gathered it was older because it had all the old part numbers and the links didn't go through. There are still reviews being posted so The site is still active. I hate when I read a review of something I would like but being so old (2-4 years) the tool is not carried anymore. And I agree with you about the HF site not being afraid of posting negative reviews. I like that.
Pulley Remover and Installer Set
U.S. General - item#40749
I just used this puller today and it worked ok I got the power steering pully off and back on but it needs to pass the 6 month test before i give it a real pass. It was on sale for $12. At least I got it in my box to fill the void. If it breaks next time i will be forced to get the OTC puller for a little more $.
subarub4
Connecticut
Yeah I too have been to that review page and I saw all the old stuff.. some of the old stuff had me wondering.. HF used to sell inverter generators.. what happened? They used to have suitcase generators..
jamesbumdaddy
Hi all. Someone recommended I post my reviews of HF tools here. I have been posting on the coupon thread.
Another Review of the 18 Volt Cordless 1/2" Variable Speed Hammer Drill. There was a Q for it ITC but it already expired so us the 25% off.
Follow link below for the video and watch for all the goodies about Harbor Freighting.
Attached Q for some drill bits that might come in handy and the 18 Volt Cordless 1/2" Drill/Driver With Keyless Chuck if the Hammer Drill is too much for you.
Happy Shopping!!!
ChevyEFI
Phoenix, AZ
Happy Shopping!!!
63 minutes? Don't get me wrong; I needed a review on a hammer drill myself. But...
It's not even internet attention span that leads me to say: Brevity in production is necessary.
jamesbumdaddy
It's all raw footage, no edits, no cuts. Just skip through it or go to the end. That's what my daughter does when she gets bored. Although you might miss out on good info and links. Thanks for watching.
jeffk14
GA
Happy Shopping!!!
Hey, I've got that drill bit set. They're AMAZING on plastic and styrofoam!!!:lol_hitti
jamesbumdaddy
Well I might have to replace one of them for doing that review. Nah, I'll just get the drill bit sharpener at HF and do a review on that. Thanks for watching.
R M
left coast
Fail in so many ways it seems endless
Jumping over all the typical reasons like design rip-offs, patent theft child labor, poor quality and substandard materials. Let's go to the core of "Fail" HF evoks ineptitude, replaceing age old craftsmanship ideology with a get-R-done must be quiting time somewhere paradigm.
Building things to last only until payday works good for Movie Sets; but those Hollywood Set builders are master craftsmen that have not sacraficed quality for a quick buck. Building with an eroded since of value that puts a $2 dollar hammer in the hand of a street corner laborer is destructive to both our culture and economy.
tedsters
a buddy of mine has a ton of HF tools, he has 3, 4inch angle grinders from HF and the first thing is take the 4 screws out of the head cap and pack full of grease it is smoother running then my 4.5 craftsman
jeffk14
GA
Yerp. Saw a Milwaukee at HD today. Eerily similar to the "high end" HF model that frequently goes on sale for $19.99. The Milwaukee was about 80 bucks IIRC.
emeraldcoupe
spring hill, florida
thanks, that was VERY helpful. :thumbup:
