The Harbor Freight PASS/FAIL Thread...
ineedtools
SouthWest Florida
The torque wrenches have been thoroughly tested to be great. Heres some great info for you all. I found one of my wrenches to be spot on out of the box, and had to make slight adjustments on 2 of them. The 1/4 inch was spot on, my 3/8 and 1/2 inch were off about 4-5 ft lbs prior to me calibrating them as shown in videos.
http://www.hotrod.com/how-to/additional-how-to/ccrp-1304-torque-wrench-testing/
Thanks for the links, book marked for future use!
Harbor freight 7 amp electric pole saw
item#68862
Great item
$63 with coupon, picked one up and after a bit of trial and error to find the right chain tension pruned up a couple hard maples. Cut through 6" limbs easy.
Worked so well I used it to buck em for firewood rather then getting the real chainsaw out.
NO idea on lifespan, but lasted this job fine, and its worth 60 bucks to not be playing with a manual pole saw for hours, or playing with a chainsaw on a ladder.
I was on the fence and bought a manual one from HD, now after reading your review I wish I would have put the $25 towards the HF electric one.
dkop1
Pennsylvania
Central pneumatic 3/8 air ratchet, pass. Lower torque than a snap on I had borrowed once, but again looking at the price point.... Beyond good value. Wish it had more than a 90 day warranty, but still, not bad for $15 after coupon. Awesome for radiator, water pump (after bolts broken loose), etc. I loaded it with oil before first use and ran it with 100 psi, woops.... Shot a nice mist of oil across the shop wall xD be careful of that
Sent from my MotoE2 using Tapatalk
Andy Griffith
Western WA
Haul-Master - item#69853 PASS
Rubber Wheel Chock,
I bought 2 of these to chock my 6x12 box trailer for moving, they really hold tight. I think I am gonna add a nylon pull strap to them and they will ride in my trailer full time. Long term durability is yet to be determined.
I agree, these are a very good value. I have some of the 69853 and some of the 69828 (rubber wheel chock w/ eyebolt). I prefer the 69828 as it has more mass and a larger surface area, but it is also twice the price as 69853.
I have these chocks in all of our trailers and tow vehicles. I put a heavy duty zip tie on each one for easy removal and carrying.
ndr1968
Oklahoma
I give the under-hoist tripod jack stands a conditional PASS. Make sure that all of the pasrts are in the easily damaged boxes. Instructions have an error about which end of the small, silver middle support brackets goes to the center ring. And the screw-up pad doesn't actually screw up and down very far (only about 8 inches). Other than that, these should do the trick for most things if you need to support things coming off your car on a hoist or over a pit.
I did a search for this and could not find "under-hoist tripod jack stands"
Part number please! Or a photo.
wildbill23c
Idaho
20-gauge-wide-crown-stapler-68029
Pass: Ive had for a few months now-rarely pic up the Arrow manual .
Used again to day-had to open up wifes recliner to do some repairs. Bazillion staples-As to finding staples for it, any hardware store-uses any T50 staple (5/32" to 5/8").
ammo-box-61451
Pass: Small but perfect to store above stapler and all its assorted staples. Should have picked up a couple more.
Great idea for the ammo box. Too bad they don't build something larger to store pneumatic tools in that is stackable so I could clear out a couple drawers of my tool chest LOL.
wildbill23c
Idaho
item#68862
Great item
I 2nd the Pass for this saw. It does work great. I used mine a couple times to trim some maple branches. It works very well. Had issues at the beginning trying to get the oiler to work though.
subarub4
Connecticut
Ok this is the 2nd time I used my 750 lb engine stand (red one) why does this stand lean so far forward with a light 250 lb or so subaru engine? I'm thinking about getting the 1000 lb one but I heard people were putting better rated bolts in.. Is it the bolts that are flexing?
TAMPAGT07
Palm Harbor, Fl
Pass- Backpack Sprayer
I bought this a while ago for my Landscaping business to spray weed killer and it works better than the expensive name brand sprayers, I've had other sprayers that always would break and not work properly.
The HF Sprayer only cost $25 and its much better than a $75 sprayer that most landscapers use.
I just picked up one of these today.. I'm going spray some chlorine with it tomorrow on my cement roof... Hope it holds up...
Craptain
Tampa Bay FL
It should do fine. But flush it through really well with fresh water when you are done. The chlorine breaks down the plastic parts in the nozzle.
Sent from my LG-D801 using Tapatalk
Andy Griffith
Western WA
Please, no more stickies.
Too many times Discussion forums end up with half a page of stickies that I suspect few people ever look at.
Just say No to forum death by stickies. ;)
I've found that just subscribing to threads that are of interest to me is the simplest way.
Did I mention how much I like the HF moving blankets?
I use them for all kinds of tasks around the place - lay them down on the muddy ground when working on a installing a new cattle gate, lay one out in the bed of my truck so my buddies and I can lay our rifles/pistols on while out shooting or to lay on while shooting from the prone position from truck bed, cover up shop equipment or other items in the shop to keep the shop dust/dirt off them, put one on the ground to crawl under a vehicle, put one in the bath tub so I could set the toilet in the tub while replacing a toilet/floor gasket, etc.
I have no idea how they work for moving tasks though.
ndr1968
Oklahoma
Which one? They list nine of them!
Noland
Yes these are very nice. I use them for all sorts of stuff. I put them on sawhorses if I want to sit painted stuff on them to prevent scratches also works well as a fender cover. I commonly use the small ones. I think they're all about the same besides size though. I also picked up a wide crown air stapler because it was mentioned and I wanted one for upholstery reasons. Was surprised how powerful it is. haven't used it much yet but seems alright
Andy Griffith
Western WA
I have a half dozen of the 40x72 as it is a real handy size.
http://www.harborfreight.com/40-inch-x-72-inch-movers-blanket-47262.html
For example used them to cover the lift arms and protect the side of the boat while I worked on the inside of the boat.
Cat bed. In this case Boots is supervising me build a deck.
Provides padded surface for important items.
And I like the 60x72 size although it looks like that one is in the 'clearance' section so I don't know if that means it's going away?
http://www.harborfreight.com/72-inch-x-60-inch-movers-blanket-93156.html
I have two of the blue 72x80 but don't seem to use those as much as the other two sizes for whatever reason.
http://www.harborfreight.com/72-inch-x-80-inch-movers-blanket-66537.html
It wouldn't surprise me if the stitching was in fact better on the camo blankets. I may try one of those next.
The bottom line for any of these 'blankets' is they are cheap enough that if I screw one up I can toss it out, and I don't risk trying to wash a greasy, dirty, blanket in the wife's washing machine.
mike_s
are the Harbor Freight "Jumpstart Battery packs" any good?
Ones like this. You routinely see them in the coupon ad's for $39
Craptain
Tampa Bay FL
My thought is that for about $20 more I bought a lithium pack that is much much smaller and lighter with same capabilities. It has worked well for me. YMMV
Ford52PU
Coatesville PA
I saw a post earlier on here for the
item#68862
I purchased one this week and used the heck out of it yesterday, got it cheap $70 and it has paid for itself twice over in one day. Thanks to the previous poster for the review and just wanted to add my .02 cents.
garandman
Boston MA / Mt Sunapee NH
We have the top-rated Anti Gravity Lithium pack. But we also have a Clore JNC660 as the Lithiums do not work well in cold. They are small and light enough to take in and out with you, and are popular for cold-weather motorcyclists as bikes usually aren't designed for cold starting.
We bought the HF jumper box a few years ago and returned it. My boat batteries were run down and it took almost 10 minutes of charging time to start them. With the Clore they started instantly.
Bottom line we don't buy much of their electrical stuff.
revrnd
Last month I picked up the bench top blasting cabinet. After a bit of fiddling, it works well. PASS
We found that the 1st nozzle was blocking the media's travel due to a shallow "countersink". Switched nozzles for 1 w/ a deeper countersink & all is good. Hooked up to my Shop-Vac & there is no dust issues.
a-b3
Picked up a 50' electrical fish tape over the weekend to pull some wire for a tv outlet in the garage. Did the trick for $7.99 plus the 20% coupon. Pass
Would most likely crumble from everyday use, but if I was an electrician I would have something better.
CJM8515
Until you run across a car with a bad alternator that backcharges and destroys it, the lithium batteries fail or you need to jumpstart more than 2 cars in a short period. Those little packs have their place, but they do not replace a real jump pack. Ive used the JNC660 forever at several jobs. Its the industry standard for a reason.
garandman
any brands/models or link's you'd recommend?
From CR
Of the 10 units we tested, we awarded Recommended status to five: The Antigravity Batteries XP-10, Spirit A8 Car Jump Starter, Bolt Power D28, New Brights Compact 12000mAH Mini Portable Car Jump Starter, and PowerAll PBJS12000R. These units provided strong jump-starting performance, along with good accessory charging options.
The Antigravity Batteries XP-10 was clearly the best of the bunch, with two USB ports, several laptop connection options, and best-in-test device charging capacity.
Spirit and Bolt Power's booster packs have laptop adaptors and good device charging times, but only a single USB port.
The boosters from New Brights and Powerall have two USB ports, but they lack laptop connectors and ranked toward the bottom in device charging capacity.
But as CJM8515 says, they don't replace an AGM unit like the Clore JNC660 (which we also have) that will start a cold battery when cold. Those Lithium packs don't work well once temps get below 30-40.
wildbill23c
Idaho
I think it has something to do with old stock verses new and improved new stock.
Exactly right. Some locations don't sell very many of certain items so the old SKU's still exist in some areas. While other areas are selling that item very quickly and the newer items that have supposedly been improved upon will have a different SKU.
FigureItOut
Bentonville AR
Anyone know the difference between the red and black composite ratchets and the grey and black ones? Is it only the length of the handle?
Provincial
Near Salem, OR
Can anyone explain why HF has so many different sku# for identical products?
It can be different variations of the same item based on 1) Vendor, 2) later or improved design, 3) different purchase order from HF, or 4) HF trying to confuse buyers with different numbers for the same item. ;)
FigureItOut
Bentonville AR
I am thinking gray and black were old stock. And red and black is new improved version.
I see. The grey and black are definitely quite a bit shorter. I have the 1/2" flex head and the 3/8" roto head and love them. Picked up a 1/4" grey composite and 3/8" red composite today, looking forward to checking them out.
