Do you use them at work. Or are they for your home shop. My set for my home shop have held up fine.Has anybody used the 1/2in impact swivel sockets? Will the explode immediately or are they worth a shot?
Sent from my SM-N900P using Tapatalk
I believe those were the ones recently discussed in some detail in their own thread. If I come across it again I'll link it for you.Has anybody used the 1/2in impact swivel sockets? Will the explode immediately or are they worth a shot?
I would apreciate that. The search function does not seem to work on Tapatalk app.I believe those were the ones recently discussed in some detail in their own thread. If I come across it again I'll link it for you.
Sent from my SAMSUNG-SGH-I337Z using Tapatalk
It doesn't work great in a browser either. To search, I usually go to a browser, type "(search subject) site:garagejournal.com"I would apreciate that. The search function does not seem to work on Tapatalk app.
I've been using these little 1' fiberglass rods for about a year and they've become indispensable to me
I've been using these little 1' fiberglass rods for about a year and they've become indispensable to me. I use them to route wires out of the way and protected, minimizing the parts I have to remove to use the best routing. They work well for pulling wires through a firewall grommet, around the dash area etc. I've broken a couple trying to bend them more than I should, but they're a definite pass. http://m.harborfreight.com/3-16-inch-x-11-ft-fiberglass-wire-running-kit-65327.html![]()
Pass ball joint service kits
Oh yeah, don't get me wrong. For their intended use in AC wire running I wouldn't consider them for serious work. I have LSD products for that. They're handy little guys though.I have the longer set, and while they are OK, I have broken the brass studs on about half of mine. Cheaper than a quality set - so if you are a homeowner doing some basic wiring, they are OK - but if you make your living fishing wires - run away.
For the rest of teh GJ crew:
http://www.lsdinc.com/index.php
Good point.
Their stuff is like some guy was working, and thought "I wish they made a tool that.....", then had the resources to make it.Labor Saving Devices..... I could have used some of that when I had to fish a wire to recessed lights instead of the two coat hangers with hooks on the ends!![]()
I bet watching experienced people fish wires is entertaining.....lots of tricks I'm sure.
And hence the Harbor Freight Pass/Fail thread, ha ha.Unfortunately for the DIY'ers, the cost for a one time use is probably prohibitive. But then again there is nothing like doing a job with the right tools!![]()
Does anyone have any experience with the hydraulic wheel dollies? Part number is 62234 or 61917
Thanks for any input
Both of those are ratchet jack type. AFSIK they no longer sell the hyd. version. I have 4 of the hyd. ones, and the storage rack they used to sell for them. They work great, very easy to jack up, easy to roll, no leaks. A little stiff when changing direction, but still, I can put a car any where I want it by myself.
I would guess these ratchet type are the same as far as the castors are concerned, but can't comment on the jacking mechanism.
For any HF item I suggest to sort the reviews (on the HF web site) by "Lowest Rating", since the default sort is "Highest Rating".
jp
That's what happened to the spring compressors I mentioned & it's pretty scary to have a spring stuck on a broken tool. I worked in a shop that had the ball joint kit for everyone to use & we did a lot of fleet work so they were used at least twice a day. Maybe their infamous inconsistency
T handle tap ratcheting wrench #97633 is definitely a pass...
http://www.harborfreight.com/t-handle-tap-ratchet-wrench-97633.html
I tapped 46 holes last night with it and it made the job so much easier. I was pleasantly surprised.
I got one of those. The first one was defective, but the exchange has been great. My favorite tap wrench. I suggest trying them out in both directions before leaving the store though.
have u tried there tap set itself been looking at getting one
I have an older USA made Craftsman set. I still have flashbacks about the tap and die set I bought in 1981 from an army/navy store that broke just from looking at them. I think they were $9.99. They were what was referred to as "cheap jap ****." Kinda puts me off to trying the HF ones.
Mine are fine. They see fairly limited use but no problems yet. I have those, the locking 3/8" extension set, and the 1/4" extension set that includes a couple extra long pieces, all good so far.How are the 9pc wobble extension?
