The Harbor Freight PASS/FAIL Thread...
Mickey O
Chicago, IL
how is this helmet .......
Kobalt
Autodarkening Helmet
Item #: 190724 Model: SGY-A2
$138.00
same helmet as the HF one ...............
price does not tell all
For welding helmets I wouldn't buy the Kolbalt or anything but the best and definitely not imported. Don't think because they are approved that they are okay, they send in nice ones for approval. You want to buy cheap stuff, whatever, but for your own sake don't skimp on a welding helmet. I'd use a decent non automatic before trusting a Harbor Freight auto.
tcianci
Walpole, Ma
One of the things I have noticed about the cheaper auto-darkening helmets is that they respond more slowly to the arc. I'ts all milliseconds or fractions thereof but know how fast is fast enough.
trythis
st louis
On this helmet topic, (way off topic) stay away from the new Selstrom stuf. I ordered replacement parts for my 10 year old autodarkening. The replacement parts fit horribly. They leaked around the insert. They were made in China. I tossed them, used the old parts and just went back to using tape.
I am not saying the HF units are ****, just be careful about the light leaks.
If it doesn't leak, they should be safe.
ATTappman
580 Lb. Capacity Four Drawer Roller Cart - conditional PASS.
Doesn't fit together perfectly, needed some lubrication to quiet some squeaking, but the drawers and casters work fine. Got it with a $99 coupon - definitely worth the money since I'm not too picky. Probably would not stand up to daily use and abuse.
Chris Adams
On the auto darking helmets, got a E-mail from someone in the know.
All the circuit boards in every brand are imported.
Surprise surprise (in my best Gomer Pyle voice)
ATTappman
It's not imports that I hate. It is cheap quality tools. I buy a lot of stuff from HF but with a very discerning eye. They sell a lot of junk but at the same time they also sell a lot of stuff that is OK to great. I'm just very careful. I have a US made auto dimming helmet and to be honest with you, it doesn't work very well.
How about posting the HF stuff you like and don't like, and help other people out? That's the purpose of this thread.
On that note, 2 Piece 11" 20° Offset & 45° Angle Long Reach Needle Plier Set - PASS. A little rough around the edges, but they work. The steel rusts quickly if not kept oiled.
CamarosRus
Renton, WA (Seattle)
Dont listen too ".............", I bought and use the HARBOR FREIGHT (Item # 91214) Flame Design (Ive removed the flame stickers) Auto Darkening Welding Helmet.
The darkening works fast and its safe......and it cost $39 on sale!!!!!
You want a professional helmet like a MILLER, or Speed-Glas spend the $300.
2002maniac
Utah
In my experience, the HF auto darkening hood works ok, but takes a split second to darken. This really isn't a big deal if you are laying down a handful of long beads, but if you do a few hundred tack welds you will feel it! After experiencing this, I went out and bought a miller hood.
My eyesight is pretty important to me.
Bull
Keep it on-topic, please.
The thread has a specific, informative purpose. It's not Fight Club.
myridge
Picked up a Harbor Freight 92652 Plasma cutter today. Its discontinued from HF but if you can buy a used one I recomend it. PASS These are made in Italy and are nice the torch is an ALPHA 3 pilot arc and its a quality unit. Consumables are readily available as I picked up 10 tips and electrodes still sold at HF on my way home from picking it up. It cuts 1/2" and is 40amps 35% duty at 40 but 100% at 20amps which is what I'll be using 95% of the time.
Very nice solid unit. Not the Cheaper Chinese one they sell now.
Scooterfish
Northern Indiana
HF has the #3000 lb. lightweigt alum. jack reg $99 on sale for $59. Is this a decent jack for home owner use? I know it`s not an old high quality rebuildable USA jack which I continue to look for. Has anyone been able to use a 20% off on a purchase like this?
Thanks
Scotto
South Jersey
Thanks
Looks like a pretty good jack, but the 14" height wouldn't fly for me. You can't get a 6 ton jack stand under the car at that height without using some 3 ton jack stands first and then putting the car up higher with wood blocks on the jack. I'd spend the extra $$ and get a higher lifting jack.
Joelfke
Mt Holly, NJ
I have a couple of those cotter pin sets from HF and they are "ok" but they are made very cheap. I can easily bend them with my fingers, where a real "made in USA" pin usually takes pliers to bend them.
agreed. but for 6 bucks its not bad
jschu121
se PA
Spot weld cutter. $4.99 and it comes with two cutters. I used it on ~30 spot welds taking off my radiator core support and it cut like butter throughout. A pack of $3.50 (10) 1/8" bits makes for a useful spot-weld cutting setup.
M900
Sarasota, FL
Spark plug boot pliers
32867-ADD
They work but the rubber coating on the handle and gripping part feels like its coated in sugar. Sticky and gross.
They werent like that when I first got them.
I went on vacation for two months and when I got home and used them they were sticky. I have no clue what happened to them sitting in my climate controlled house to make them feel like that.
I used a razor to cut the rubber off and I coated them in plasti-dip.
Much better now.
Art From De Leon
De Leon, Texas
Much better now.
Mutating.:shocking:
Danglerb
SoCal
I've seen plastic seemingly at random turn to goo. Usually its something like a rubber "foot" or pad on the bottom of something. I had a modem stack once, all the same, and three of the pads were good when I took the system apart and the rest were fine.
Ttankersley
Hendersonville, NC
I agree with the fit and finish of it. I got mine for $99 + 20% coupon. I will disagree on its durability though. I have been using and abusing mine for the last 10 months or so in a shop environment. Knock on wood. It's loaded to the gills too.
Timmy
Fujisawa Rob
PASS:
3-ton Super Heavy Duty Floor Jack #34271. I found a $60 coupon for it. Works great,very solid (weighs about 100#). This was probably already mentioned, so +1 if it has.
Can anyone tell what the difference is between their two 8" bench grinders (other than the price)? 39798 and 90022.
I've got a lot of HF stuff, and my experience has mostly been positive. Only a few things were horrible, and they were so cheap it's not worth worrying about. One that comes to mind is
FAIL:
Electric Paint Spray Gun #47274. Got on sale for $12. Totally and completely useless. I couldn't even get it to spray plain water, let alone any water- or oil-based stain, and certainly not paint.
I'll go through my list and post the good and bad.
djjsr
In the cornfields
Rotary Hammer - PASS++. Can't beat it for the price ($50 w/coupon) but the bits it comes with aren't too good. Had better results with the Drill Master bits.
Multi-Tool- PASS. Handy little gadget that I probably won't use much but it was only $35. Works good for scraping, cutting wood and light sanding in tight places.
mossyboy6
St. Pete, FL
BIG PASS
Use this almost every day and hasn't failed yet.
I have used the fein tool and the dremel version, this one is almost as good as the dremel, and about half as good as the fein. Great value.
Fujisawa Rob
I had a $30 coupon for the multifunction tool. I haven't used it yet, but it looks promising. They also sell a variable speed model. I believe Dremel and Craftsman accessories MAY work with it.
I also have the rotary hammer, and it rocks. I don't recall how much it was but I want to say $35. I bought a chisel bit for it and it made quick work of breaking up a travertine countertop.
olds88
New York, NY
PASS 1 ton engine hoist. Successfully swapped a 5.4 Triton on an 04 F-150. On sale $130, can't beat that w/ a stick!
jwitt
Pensacola, FL
Got one of these for Christmas
And added one of these to it
Pass on both, my knees and back are thankful
Jim
jeepnut24
Morrison CO
How well does the scraping action work? I want one of these to remove the factory sound deadener in my project car.
arvidj
Minnesota
Jim
I've had the 1200 lb air powered version
for about a year. Replaced the front wheel vice with with this wheel chock
The 750 GSXR rolls on and off without any problems and it saves space in the garage because I store the bike on the table. The platform is just wide enough so I can use my Pit Bull rear stand on the spools to raise the rear wheel off the table for chain maintenance. I've also used both a fork stand and a triple tree stand on the front for front end work but the incantation is to put the bike on the Pit Bull rear stand, I can then remove the front wheel chock to get it out of the way, then use which ever front end lift I need depending on what I am doing. Yes, a minor PITA but still easier to have the bike on the lifted table than to work on the bike on the garage floor.
And as part of the bonus benefits, the wife is willing to lift up the bike to a level that she can easily clean it when it is a little dirty. She would not do that when she had to stoop down :).
j-easy
tcianci
Walpole, Ma
Just got the HF 2000lb remote control utility winch. Tentative pass. It's model#92860. I bolted it to a piece of 2x4 to span the door jamb at the back of my garage. I'm going to use it to pull my hobby truck back in to the garage when I need to roll it out for using the garage for other repairs (it's not easy to push the truck back into the garage in the snow.) I hooked it up and ran it, actually sounds nice and smooth. Since this is a pretty light duty application, I expect it will work fine. I will report back on my experience after I tow the truck back in tomorrow.
toxicz28
NY
Just got the vehicle dollies. Mixed review.
Cradles, nice heavy gauge steel: PASS
Casters, with .106" of slop in them:FAIL
onebadtwo
These are a major FAIL! I put some under a Ford ****** and the wheels fell apart within the first 3 feet.
