The Harbor Freight PASS/FAIL Thread...
Pastenseverb
Utah
Is this drill decent?
Asking because this is cheaper than buying replacement batteries for my old drills
Nothing is more frustrating than having a nice drill (set with saw sander etc) that the batteries are gone. I took my batteries and had them rebuilt at half the cost. The amperage went up to 2100 and life will last a few years longer. (As stated by batteries plus owner). I hope he's right. So far they have been awesome though.
owenst7
Anchorage/Reno
Three Ton Jack Stands : Fail!!
See photo. Just holding up an old Imperial, sort of!
Looking at your photo made me realize that if you don't bend the little retaining tab in, you can potentially engage teeth lower on the cast portion, making the stand taller. Looking at my 6 tons just now, its a difference of almost 3 inches. That would certainly increase bending moment on the cast portion, along with preventing it from properly engaging the throat that makes it stable.
I'm not saying that your stand failed due to that, but I do think I will make sure the tab is bent and/or I make sure not to overextend any stands in the future.
On the other hand, I made wood cribbing out of dimensional lumber screwed together. I use that under a jackstand whenever possible to limit the extension on the saddle. They are way more stable that way.
I also try to throw a tire or leave the floor jack in place. Always like to have a backup plan. I also use 6 ton jackstands on pretty much everything that's going more than 16" off the ground. 12 tons if they get much higher than that. Basically use the widest stand possible for stability.
1Garageman
Columbus, Ohio
I don't know how much money you are wanting to spend, but those drills don't last long, and will need replaced shortly after buying them. Do you have a Menards near by??? They have some good deals right now under $100:thumbup:
Bosch Drill!
mike_s
It will work but it's not powerful at all and it has a noticeable amount of chuck wobble. I would recommend buying factory reconditioned drills, at times you can find Milwaukees for around $130 with impact driver and two batteries.
A friend of mine bought a recon Porter Cable drill with two batteries for $50.
The HF drill can literally be stopped in drill mode with your hand on the chuck.
Thanks.. .that's the kind of answers I was interested in. I thought this would be junk.
I thought about rebuilding battery packs. we have a local "battery plus" that will do it, but I can buy new ones cheaper.
Not same drill. (by visual or part numbers)
medic502
South Carolina
...and the recalls...
...and the fact that my BIL's 300ZX is in my way in my backyard rotting because the wiring harness melted because of those substandard defective fuses.:mad:
Just a word of caution.
So is the small box... 67664 considered bad also? 8f51d6748fba3d870fcd63ec5a4ed774.jpg
Sent from my XT1585 using Tapatalk
MilwaukeeFish
Milwaukee
I don't have a definitive answer for you on your question.
However, personally I wouldn't roll the dice with any Harbor Freight fuses.
The possibility of having a 10 amp rated fuse holding until it blew at 76 amps, just isn't worth the minimal savings compared to the potential damage that would be caused by such a device.
FigureItOut
Bentonville AR
That is frightening. I've never bought fuses at HF, but I use a lot of them and I get fairly cheap ones. I'll have to reevaluate that.
Sent from my SAMSUNG-SGH-I337Z using Tapatalk
Andy Griffith
Western WA
Re: HF fuses.
I don't think I have any HF fuses but I will check my small collection to be certain.
I just wanted to post and thank those who have contributed to providing information about the fuse issue. This is an important safety issue and spreading the word on this issue (or any other safety item) is very much appreciated.
This particular issue happens to be about HF fuses, but passing on information about Any manufacture/product issues is helpful.
One would think with the wonder of the internet most everyone would be informed about these type of things, but that's often not the case. Better to be safe than sorry.
Thanks again.
Back to your regular scheduled programming...
cheechi
Triad, NC
Thanks all for pointing this out. I don't think any of my fuses came from HF. What kind of markings would they have if they did?
All of my fuses say Buss except the mini 10A that say 'pacific' is that possibly a HF brand?
I don't think I bought any HF fuses, and I don't think I would just have one type if I did, but always good to be sure.
FigureItOut
Bentonville AR
I have one. It is as good as the Toro it replaced, as far as power goes. Only got it last fall, so no idea how long it will last.
jp
You were right, pretty impressive power for the price. It's safe to say I was....blown away.
Conditional pass from me though. I had to exchange it for another. Every time my hand got near the switch while running it gave me a little shock. I've had that happen from quality brand electrical stuff so I'm gonna give it another shot.
http://m.harborfreight.com/3-In-1-E...1016_c1316a&utm_referrer=direct/not provided#
1Garageman
Columbus, Ohio
The pressure regulator on my air compressor needs replaced. Are any of the Pressure Regulators with Gauge any good at HF??
http://www.harborfreight.com/38-in-air-filter-with-regulator-68232.html
TalonFE
New Mexico
1000lb Motorcycle Lift-PASS. Had this one for nearly 10 years w/o defects, although the front wheel clamp is too small, easily enlarged with some plywood cut to fit. It's HEAVY, but stable and the safety device to prevent accidental collapse is very robust and idiot proof. It's not air-powered...but very controllable with the foot levers both up and down. I store mine vertically, strapped against a wall when not in use and no leaks from the hydraulic cylinder. A bit pricey currently at $429, but 2-3 time a year they go on sale for 199.99 or thereabouts. Hard to do without now.....highly recommended.
Yesmar
Harrisburg, PA
im sure its already been said but the socket trays,like the henson trays are a no brainer. they are not indestructible but they do their job for a great price. Its a piece of plastic organization item thats it.
morgantm
Durham, NC
They go on sale for $299, I have never seen it on sale for $199
skulldrinker
Bolingbrook, IL
How on earth do you lift it up? thing weighs a ton. Engine hoist?
micro2112
I am planning on picking up a few items today many without specific coupons, does HF apply the 20% coupon to multiple items, or will i have to make multiple buys?
FigureItOut
Bentonville AR
Vette10R
MN
I'm heading to HF now, I think I'm going to grab the 2 ton low profile I linked in post 8076. I found a coupon for $129 that's not to bad for what it is...
winlinmac
USA
^^^Been working fine for me as well. No complaints, make sure you keep a bottle of hydraulic jack fluid handy
Vette10R
MN
I picked up the 2 ton today, haven't had a chance to use it yet. Maybe tonight when I get home.
goodysgotacuda
DFW
That one with the drop knob at the end of the handle is a very good jack. I have used mine for a few years and love the reach it has.
soloz2
Western NY
I've got one as well and it's a great jack, but since I sold/traded both my low vehicles I rarely use it as my 3t jack is just easier to maneuver
Sent from my A0001 using Tapatalk
CRXPilot
west TX
The Low Lift Transmission Jack 69685 is a solid Pass. I just lifted in a 4l60e yesterday and it worked fine. The cylinder was ready to lift, no need to bleed it. The adjuster knobs are a little stiff and I would recommend lubing the threads first. I didn't but it was still usable. It turned a 2 man balancing job into a 1 man, 30-minute breeze.
Zapp Branigan
I have the steel one you're talking about, and an aluminum one. Both have served me well for a couple years. The steel one gets used a lot more and I definitely prefer it
I have the same one. It's been great. I've been using it for about three years now
