The Harbor Freight PASS/FAIL Thread...
paulf
HF 18v Impact wrench "Fail" picked it up, charged the battery 3 hrs the light indicated it was done.
Tried to remove wheel lugs from two of my cars the wrench could not loosen either one.
Brought it back the next day
Guess I will have to keep looking.
Any suggestions ?
Thinking of Bosch, Makita , DeWalt or Snapon,
I also want a 3/8 in cordless impact and it would be nice if both used the same battery I think Lion batts would be the best as I don't use them often
Thanks
Paul
cide1
The straps on their welding apron caught fire, and kept smoldering. I hung it up on the wall not realizing, and ran a 30 minute errand. When I came home, I open the garage to find it filled with smokey haze, when I finally figured out it was the welding apron. I'm lucky my house didn't burn down.
This was the end of me buying much from Harbor Freight.
Danglerb
SoCal
Any suggestions ?
Thanks
Paul
Reasonable punishment for assuming the HF cordless impact would take off lug nuts would be buying the Snapon CT7850 $659.95
Nothing cheap is going to reliably take off lug nuts. Milwaukee high torque should also work, everything else pretty much is a maybe.
787B
Baltimore, MD
Hogwash. I am an amateur road-racer and hi-speed track driving instructor. I'm constantly taking tires on and off my race car and street/track car. Hell, I take the wheels off just to clean them.
My weapon of choice for the last five years has been the $70 Goodyear-branded impact gun from Pep Boys (now branded as Great Neck?). After five years, the NiCD battery still holds a full-weekend's worth of charge and has no problem removing lug nuts from even my 3/4-ton truck. Only thing I've done to maintain it is yell "Who's your daddy!" at it every now and then.
Just because it's cheap doesn't mean it's ****.
Just because it's expensive doesn't mean it's not ****. :thumbup:
1984Datsun
has anyone had any experience with their new Badland brand of winch??
Nope, but based on a review in a four wheel drive magazine article, they say the only downsides to the HF 9000 pound winch is the slow winching time. Expect the same for the rest of their winches... a fair bit slower than top name winches, but also cheaper and has potential to last much longer since the motor doesn't have to work really hard to pull a line really fast.
The upsides are low amp draw (you can thank the gear ratio), long expected life, and good reliability.
I will get the 12,000 pound version to bolt onto my custom front bumper once I get it done and mounted on my Ranger.
The reviews are enough for me, and given that an actual four wheeling magazine tested it and liked it better than most of the other high end winches, that tells a lot right there.
Just type in "is the hf winch any good" into the google search bar... you'll find a good amount of reviews and personal opinions on that winch.
Danglerb
SoCal
I didn't say its ****, I said reliably take off lug nuts. I understand some people have had good results with a number of cordless impacts in the same class as the 24v Goodyear, but I would still put them one step below reliable lug nut removers. Good luck with NiCads is also hit and miss, again NiCads are not in my list of things I would recommend as reliable.
Personally I haven't decided if I am going to try one of the $100 cordless impacts, jump up to the $200 range, and skip it for now and stay with air tools or a breaker bar.
cderalow
Potomac, MD
i think the '24V' goodyear is made by the same folks who make my 18V ryobi, which will take lugs off my car (properly torqued) if I use the Li+ battery, but not the NiCAD.
nuclearlemon
denver
not necessarily. the motor may be working just as hard, it's just a cheaper probably smaller motor.
again...not necessarily. have you ever known an 'actual four wheeling magazine' that bashed a product. nope. they are horrible places to get reviews.
that said, i know one person who has one and has said it's worth the money. i've run enough low end winches in the past that i won't anymore, so i don't have first hand experience, but brian runs his winches more than i do and he's happy enough.
ishiboo
Oshkosh, WI
Not cheap, but the Bosch is rated for 50 ft-lbs (max) over the Snap-On, is cheaper, and the major advantage for those of us who don't need a dedicated impact wrench is the batteries and charger work with all the other Bosch Lithium 18v goodies.
Hakcobra
Tri-Cities WA
I just picked up a 800lb HF Transmission Jack today for $97 (gotta love the family discount as my cousin works there :D ) I am R&Ring my 2000 Expeditions 4R100 and will report back as to how it goes.
UPDATE---Pulled the transmission out the the expo today and the transmission jack worked great! Ended up fabricating an adapter bracket to bolt the transmission to the jack (similar to what Ford does) and it worked perfectly. Made handling this heavy transmission a breeze.
-Kevin
econoaddict
Oregon
I bought the 6000lb winch (#68141) and mounted it on a receiver at the front of my car trailer. So far I don't have anything but good to say about it.
As already posted it is a bit slow but I can deal with that for the money.
wellpoison
Windber PA
stopped down yesterday and got a set of "nutsetters" and two 1/4in socket rails.
socket rails - pass
only thing i see wrong with them is length, there too long. it seems that they use the same length rails no matter what drive holders are included. they have i think 15 holders on each rail, i ended up buying two and putting all the holders on one rail. cant complain when they were 79 cents each
"nutsetters" - pass (but just barely)
i bought these for 2.50 figuring i could use them as a cheap nut driver set. they do fit nicely into my wera kraftform kompact so that is a plus but what they lack is depth. inside every driver is a magnet to hold the nut in place. i wish i wouldve checked before buying
rlitman
Long Island
I don't think you realize what you have. Those things are awesome.
Nut-setters (not nut-drivers), aren't supposed to have any depth. They're supposed to be used to drive hex cap screws such as these. The magnet retains the screw just like a magnetic phillips when you're driving drywall screws, but these screws don't cam out.
MNRZR
They are also handy for starting nuts and bolts in hard to reach areas.
TAMPAGT07
Palm Harbor, Fl
terry1769
Atlanta
I have it. The inline dryer broke and was discarded but other than that it works. It's a delicate balancing act between the two valves. Don't just open them both all the way. Once you get it set though it works reasonably well. You'll have to bump it every now and then to get the media to settle. Not the best but a usable pass in my book.
TAMPAGT07
Palm Harbor, Fl
Thanx terry1769 for the fast response...I've got to blast my two lifts and basically the whole front of my house (to prep it for thin bricks.)
soob
http://www.harborfreight.com/23-gauge-air-pin-nailer-68022.html
23-gauge pin nailer: FAIL
So I got it and it didn't shoot nails, period. So I tried adjusting the depth, which has a plastic lever. Pretty hard to do it. It's set right but I'm not sure what's up, so I change it a couple times. Around the third time, the plastic snaps. Admittedly, I was pushing it pretty hard.
Ok, so why dosn't it shoot nails? I pulled the nose apart, something looks wrong. Hmm. OH! The friggen bottom of the nose was installed upside down. I righted it, but it still misfired every pin after the first. Once the nose was installed right the depth was very easy (much too easy) to knock out of place after breaking it. I don't think that was causing the misfires; the bottom nose was just too tight of a fit around the pins.
Anyway it was the last one the store had so I guess I'll have to wait a while for a replacement. I have the brad and 15-gauge nailers and they work fine.
I did get the replacement, and it works great. Well, I only put a hundred pins through it but there were no apparent problems.
I also can't say enough how much I like these pins compared to brads. They leave a hole but it's nearly invisible from a few feet away. It would disappear under paint without filling. They seem to have really good holding power, better than I'd expected. And if you're going to use glue anyway they're probably just as good as brads.
rlitman
Long Island
My pin nailer is a Porter Cable, but I agree that I love pin nails. They're perfect to get something to hold until the glue has set, and because they go in so easy, using them doesn't disturb what you're nailing, so when I'm mitering molding, I can align the corners absolutely perfectly.
I have been warned that since pin nails have no heads, if you load the pins in upside down just once, it will damage the hammer enough to make the nailer unreliable after that.
Kaervak
Cleveland, OH
Has anyone tried the engine compression tester 92697?
is it a pass?
I bought one a while back. Definitely a pass from me, not sure how it compares to other brands though. When I did a compression test on my car, all the PSI readings were within spec and equal across all the cylinders according to the HF gauge. For the $13 price tag, it's hard to wrong. :)
subarub4
Connecticut
Ok good to hear :) I was looking at the offerings on Amazon at the same time I thought about the ones that HF had.
machine_punk
Napa Valley, California
EPIC fail...
the black and orange pistol-grip bar clamps.
Don't waste your money, even if they are on sale for $2. Every one of them I have used so far has failed at the trigger pivot point on that last squeeze to get it tight enough. My major-brand clamps will keep going until you cannot press any harder. The HF clamps just fail catastrophically. I suppose I can re-use the metal bar for some project, but other than that, they are a total waste of money.
Kev442
Wi
+1 It's like I wrote this response myself. I didn't even bother installing that inline dryer, it looked like it slowed air flow down 50% to me.
rlitman
Long Island
EPIC fail...
I had the same issue, but I didn't waste my money. I got it with the coupon when it was free. It was still hardly worth it.
I did manage to fix it though. I drilled through the pivot point, and used a 20 penny nail as the new pivot. Cut it a little long, and peened over the end.
It works ok now, but still doesn't have the grip of a real one.
losabio
Pittsburgh Pro 1/2" locking extensions (Item No. 67977) - PASS
These extensions are crazy good. The knurling is nice for spinning a loose bolt with your off hand, the locking function works great, and the chrome is nicer than you'd expect out of a $15-$20 set of extensions. The smallest one is good for giving a torque wrench a little clearance, and the second smallest one makes a cool nutdriver for starting/spinning off bolts. I've used these for 2-3 weekends' worth of repairs and I wound up buying another set for my friend's birthday and a set of the 3/8" for myself.
Pittsburgh Automotive 4 ton bottle jack (Item No. 66450) - PASS
This is a super handy little jack. Mine was on sale for around $15 I think, and it's proven to be just great for supporting/pre-loading various bits and pieces under my VW. The small size makes it easy to grab and reposition. The top saddle unscrews out of the piston for increased reach. I <3 this jack so much, you guys.
porphyre
Sometimes you know you shouldn't buy something.... but you do anyway...
HF brand Blue Painter's Tape #95512
http://www.harborfreight.com/2-inch-x-60-yards-painters-tape-95512.html
Holy. Jumping. Jesus. On. A. Pogo. Stick.
This stuff is HORRIBLE. It's like they took blue toilet paper and sprayed some craptastic adhesive on the back. You have to be very careful pulling it off the roll or it tears. It only sticks for about 8 hours before coming down. It doesn't work well under 60 degrees.... I tried to mask some stuff out in my semi-heated garage and it wouldn't stay stuck for more than about 30 minutes.
Something so simple... how do you **** up tape? HF did it. I've bought some good stuff from HF and some bad stuff. This is by far the WORST. BY FAR.
thesilverone
Taxachusetts
EPIC fail...
1 of mine broke at the same place. The other one didn't break. 4 bucks (total) for a one time use.
diernosaj
Tucson AZ
http://www.garagejournal.com/forum/newreply.php?do=newreply&noquote=1&p=1964913
1/2" Drive 25" Breaker Bar
Sale: $9.99
Inside track membership: $7.99
PASS!!!
Im trying to take the axle nut off an old car. First of all the finish on the breaker bar is nice and consistent no scratches gouges blemishes or anything. It is sturdy, stout and tough. Im standing on the bar on the axle nut trying to get it loose and nothing is budging, not the nut, not the bar, nothing.
I got a 3ft piece of steel piping that juuuuust slips onto the handle of the breaker bar and im cranking down on the pipe. The bar is taking every thing I'm giving it with no problems. I wish I would have bought it a long time ago.
IONH
Central Massachusetts
AMEN! Your post was so funny. I just helped my Dad strip his kitchen's wall paper and then paint the walls. I explicitly said "DO NOT BUY HF TAPE" because I know he's a cheap SOB and he has to go to Home Depot for paint anyway so just get some damn tape there. What'd he buy?... HF tape! :shocking:
No lie, 10 minutes after he finished taping, the tape was falling down. I pushed it back up as it fell and rubbed it into place for the first 20 minutes or so and then I said F it and just ignored it to let him deal with it. Ended up without tape on most areas and was just careful with the edging brush.
soob
I bought some of the painter's tape and used it to install a glue-down wood floor. Worked fine for that.
