First post here after reading this thread the whole day.
I've been pleasantly surprised with the majority of HF purchases over the past 10 years or so. I've been getting bolder with my purchases, moving up to power tools and electronics lately. I mean why not? I walked the power tool isle at OSH and Home depot last week and checked the origin of various Bosch, Makita, Dewalt, Milwaukee and others on display, 98% made in China, the other 2% in Mexico. HF tools probably come from the same vendors that are supplying parts for the other guys.
I've noticed some negative reviews of the HF stuff comes from people expecting way more quality for next to nothing, while better reviews come from ones who don't expect anything but a throw-away after a few uses but end up with a tool that last years after being used on a weekly basis.
EPIC PASS:
US General 700lb capacity 5 drawer red tool cart $120 at parking lot sale w/20 % off coupon. Solid, solid, solid, big casters, once my buddies saw it they ran out an got themselves one. Building tip: DON'T TIGHTEN THE BOLTS AS YOU PUT EACH ONE ON. when its all assembled and all the bolts are finger tight make sure the cart is on a level surface and all the sides are square to the floor, then tighten everything up
PASS:
-Blue cart for mig welder
-auto darkening helmet w/ shade adjustment (preferred over speedglas which I had to manually turn on and got me a few times)
-Pittsburgh 3/8 impact sockets deep and shallow, sae/metric
-3/8 impact extensions
-brass handled center punch
-single speed multi tool, few uses but great every time
-pittsburgh long nose pliers, a little soft for heavy gripping but great for spring clips in odd spots, random clips, etc.
-magnetic trays
-1/4 and 3/8 drive torx bits
-multi angle finder w/mag base
-metal socket rails, for 1 dollar ea on sale how can you go wrong
-Goodyear air hose
-sta-lube moly grease gun refill tubes
-air drill w/ 1/2" chuck
-air chisel, tips are a bit soft, but you can buy quality replacements when they are worn
-micrometers, not much use but verified against calibrated starretts at different openings
FAIL:
-plastic and brass tipped dead blow hammer, still collecting lead shot off the floor years later
-6" screw C-clamps, will sorta hold stuff but not really clamp stuff
-90 or 100A flux core welder (EPIC FAIL), just a POS I got on craigslist as a package deal with the helmet and cart above for $40. the wire was live the moment the switch was on and the trigger only activated the wire feed...WTF?
-3" air cut off wheel, no power from day one, on its way back to China via the recycle dumpster
-multi size hole saw kit in gray box
-newest batch of nitrile gloves, tear like paper
-cut off wheels, they dont last, chip easily and have a real funny smell
-Air fittings
THINGS I WILL NOT BUY AT HF:
-drill bits, except the unibits I will try based on decent reviews
-wrenches, any of them
-non impact sockets, any of them, plus I have all the CM sockets I need
-screwdrivers, used too often to warrant a trip to the store
-anything edible
-consumables like abrasives, blades, etc unless it's a known brand
-torque wrenches, I can't risk a 10-15K engine build to an improperly torqued fastener
-Impact guns, I want to have the power to break stuff
I'm sure there's more, but that's it for now
