mikebramel
My local store has 6 of them at $99 (!) Have they ever gone on sale?
mine was &70 on sale plus the 20p coupon. good deal
have the same set it works flawless and YES i have used it a couple of timesuse it in a couple of SHO's and my older f 150 never a problem and subbarub4 you do have to tighten the gauge really good
Saftey style push button air coupler: http://www.harborfreight.com/1-4-quarter-inch-industrial-push-button-air-coupler-66263.html FAIL
I could not get one to work out of four purchased. The reviews on the HF site are horrible too. Tried to save a couple of bucks over the Milton; dont waste your time.
the flux core from HF is better than lincoln?Is it different than the ones that come in their welders? b/c the wire that came in my HF wire blows, someone told me to get lincoln and it will rock
Electric angle grinder, very off-balance, vibrates horribly, I have to smack it against the ground to get it to turn on. FAIL
Well, it's an older one, but it looks almost the same as #91223 except it's blue instead of red. I don't know the model number of mine, the sticker peeled off a long time ago. Could be the same one.Which model number are you referring to?
Not sure of the wire that comes with the welders, as I never used one of their welders. I have an old Tweco MIG that I set up for flux-core, and I used to use the Lincoln wire from Home Depot since it was cheap. It worked okay. Then HF moved to town, and they had a pretty great deal on the wire. So, figuring it would probably be total ****, I took a shot anyway since it was dirt cheap. I was very pleasantly surprised. It welded smoother, very nice consistency, and less spatter.the flux core from HF is better than lincoln?Is it different than the ones that come in their welders? b/c the wire that came in my HF wire blows, someone told me to get lincoln and it will rock
Hi!
I'm eyeballing the cobalt drill bit set, on sale for $100 (or $80 after that 20% coupon).
Is it any good?
Their still drill bits have been of uneven quality... their holesaws were garbage, their standard drill bits are fine for brass, aluminum, woods but not any real steel.
Now the cobalt set I would get specifically to drill through steel: are they well made? Sharp, precisely ground, and of an alloy that will actually be harder than the mild steel I ask the bits to cut through?
Has the quality of their impact sockets gone down? I picked up a set of the 13 pc deep wells in both metric and SAE and they look like ****. I just needed a couple of spare sets but these are pretty terrible. The finish on them is like sandpaper and the size markings are tiny and in a different place on every socket.
The last sets I bought were glassy smooth and had 5 gallons of oil all over them, these are dry and your lucky if you don't cut your hands on the finish. If anyone has the 13 pc set in the blowmolded plastic case, let me know how yours are because I think these are going back.
The laser etched shallow set that I bought a couple years ago is great but not sure if it has changed or not.
I just received both the 1/2" drive 13-pc metric & SAE deep well sets on Wednesday. The black oxide finish is a little rough and I don't know how well the etched-on size markings will hold out. Both were in blow molded cases with the window. Both were drenched with oil. For what I paid, I'm not disappointed. Time will tell how well they're made.Has the quality of their impact sockets gone down? I picked up a set of the 13 pc deep wells in both metric and SAE and they look like ****. I just needed a couple of spare sets but these are pretty terrible. The finish on them is like sandpaper and the size markings are tiny and in a different place on every socket.
I ordered a set of metric and SAE impacts from HF last year.
The SAE came in a big red blow molded case with a clear window looking in. They were kind of rough textured and extremely filthy. I had to clean them like crazy so my hands didn't turn black just handling them.
For some reason, the metric came in a black bent up metal tin. The appearance was glassy compared to the SAE ones. It was as if I had bought two different brands or something. They were also kind of dirty but not as bad.
I have barely used either set yet though, except for the 15mm, which has not broken yet.
The old ones are the ones in the metal box, the new plastic box/rough sockets must be the new ones. Maybe I just have a texture issue but I still don't like them.
Hey subarub4! What is that?![]()
I posted this on the slickdeals thread so I will post it here..
Inside of the battery jump box.
Any generators mentioned? Pass or fail?
93888 Mover's Dolly - small size, 1000 lb capacity - FAIL!
They changed the design and/or supplier since I last bought these 5-6 months ago. The wheels are hard plastic and have a mind of their own. There is so much slop in the pivot that they refuse to caster when the dolly is loaded and pushed. The wood and carpet are thinner and poorly put-together. They are junk now.
What ***** is these used to be great little dollies. When they had the solid hard rubber wheels and chamfered corners they were excellent. They rolled smoothly even when heavily loaded. I have a dozen that I used in my garage to store and roll around stacks of wheels/tires, spare transmissions, spare engines, heavy cases filled with gear, and even my Snap On mid-rise scissor lift! I paid the same price for old and new.
I'm going to take the new ones back and take on old one with me and show the manager the difference. No doubt it won't do a damn bit of good, but at least I did something in addition to not buying them anymore. Guess the son who stole HF from his Dad needs to pay for that multi-million-dollar mansion in Cali...
I bought the generator too. You can get it for $64 with 20% coupon through Sunday. Initial inspection found it to be built a bit better than your average HF schlock. Fit and finish is pretty good. There are 80+ reviews on HF.com and most are positive.
Based on those reviews the first thing I did was pull the spark plug and sure-enough, the gap was set to less than 0.010". No wonder they don't run good out of the box! Gap should be 0.025-0.031. Regapped and reinstalled, but didn't have any gas to run it yet. I'll use it for a while and then give it a pass or fail. Break out my Kill-A-Watt and see if Volts and Hertz are right too under load.
hey I know they have an upcoming sale on these things but is it better to get it now or wait? I have awhile to wait like another year.. I plan on getting it to run two halogen lights that HF sells I think it was the dual 250 W
I think cost of the extended warranty would be the deciding point for me.
OTOH with HF good batch, bad batch, you don't want to pass up one now if this is a good batch.
