http://www.harborfreight.com/200-lb-capacity-portable-work-stand-38778.html/QUOTE]
200# capacity work stand - I'm going to call this one a fail.
The store didn't have these assembled so I bought a closed box sight unseen. Probably not a good idea at HF.
The tubing is thin and very light gauge.
Directions were typical **** but not a big deal because the item is easy assemble.
Although I think it will work for my needs, I would not trust this thing to hold 200# of anything that is being manipulated and worked on.
My biggest issue is that the tubing is dimpled at the area where the two legs are joined by a bolt to make a joint. These dimples kind of nest together. If you tighten up the bolts with the stand opened up, then the stand literally won't fold up. If you leave the bolts a bit loose so that the stand will fold up, then the joints are loose when the stand is set and seems unstable.
Part of the reason I bought this is because I thought "if I made this, it would cost way more in materials." I'm not sure in this case. The tubing seems really cheap and the end product looks extremely light duty.
If the store had one in stock I would have tried the 500# stand. Only a couple more dollars.
HF....when will I learn...
