1) No. The 50 footer is physically larger, including the diameter of the reel itself. No way 50' of hose can be coiled up on the 25' reel.
2) Yes. The cheap hose they come with has standard 3/8" fittings, and is nothing other than a cheap, regular air hose. I put a 50' Goodyear hose on mine and it works fine.
Sent from my XT1254 using Tapatalk
Thanks for your help. I'll end up getting a 50' then and post a review after a good long while. Speaking of a good long while:
http://www.harborfreight.com/3-ton-low-profile-steel-heavy-duty-floor-jack-with-rapid-pump-61282.html
PASS
Been using this for over 2 years, regular use. At the end of the first year, the lip at the bottom of the handle, that the set screw sets into and that has the square head to tighten or loosen the jack, broke. HF replaced it for free for me, but I'm not sure all HF managers would be that nice.
Otherwise, works quite well. I had to fill it up with more fluid at least twice after using it to try to lift the axle on a 30foot horse trailer, that was pushing the jack, but it did it. May have refilled the fluid once during regular usage. Recommended for regular shop duty. Worked well for most lowered cars I deal with. If the handle breaks again I may have to edit this post.
