Aquaticbob
I'm no powder coat expert, this is the first time I've ever done it so I'm basing this off of how I felt it performed, and also to hopefully get a little feed back. Lots of writing, some pictures. Needs more pictures for sure
I've been talking about picking up a powder coat gun for awhile to try it out. Only issue is I don't have space for a big oven currently, and I haven't had much needing powder coating. I do want to add powder coating to my professional shop however, so I needed to give it a shot. Since I'm rebuilding my brake calipers I figured this will be perfect for testing it on. I thought about the Eastwood unit, but figured for about $50 (with coupon) can't go wrong with the harbor freight.
Matte black HF powder and gun acquired, I also ordered a black and decker toaster oven off amazon for $20.
I know these things can be inaccurate with indicated temps to I fired it up and checked it
It ended up being 475 at an indicated 450 however 400 was about 395 so that was pretty impressively close. It held temperature very well, being able to maintain temp within about a degree over 20 minutes. So with that I figured it was time to get to testing.
The gun has a pretty short lead from the power box, the foot pedal that it comes with might have like twice the lead of the gun... Anyway, the ground is a small gater clip with a plastic cover that clips well to the piece. So I poured some powder into one of the 2 cups it comes with and went to town. The adjustable tip is a pain to deal with. It doesn't screw down easily, so be prepared for massive powder clouds. The powder was attracted right to the aluminum sheet I was testing it with. Took like 5 seconds to get it coated. Turned it off and put the piece in the oven
About 3-5 minutes (wasn't timing) warming up time, 15 minutes of curing, and about 20 of cooling I had the piece done. Overall impressed with how it turned out. Did very minimal prep (brake cleaner that's it) and only had a little bubble and some orange peel. I'll have to get better to eliminate that.
Overall so far impressed with the gun. It would be nice if the lead could be disconnected for cleaning. Cleaning the gun isn't fun at all. Takes a lot of compressed air. The gun comes with a pressure regulator and filter. Strongly recommend using Teflon tape on the regulator for extra air tight. The filter doesn't need one unless you wanna tape every time you use the gun. The lead also could be twice as long from the box for the gun and ground clamp. It does get the job done for cheap though. I will be doing more work with the gun for testing. I'll be adding to my review. Already thinking of building my own gun. This is an extremely simple tool in my opinion. I will be improving my skills on a few more test pieces before moving up to my calipers. Also expect some toaster oven modding.
My total invested in this so far is $85 as WA has sales tax. Without tax it would be like $75ish
