toolaholic
I changed rear shocks on my 07 Yaris. You are supposed to torque them on the ground. My gearwrench flex head torque wrench is only 36 tooth. I had to break out my sk 12 point sockets. I would swing the torque wrench towards ground then there was no room to click on upswing. Muffler in the way.So I had to to reposition it on bolt to get click to swing down again. 12 points give more positions. I originally torqued in the air. Very low torque spec of 37 lb ft. I don't believe i twisted lower shock bushing.I then re torqued on ground. The Yaris did seem to sit slightly higher in rear. After a week it settled to normal height. Just to be sure I didn't twist lower shock bushing loosened shock and torqued again.
